Question about Sharp MD-MS702 Personal MiniDisc Player
MY SHARP 701 MD PLAYER DISPLAYS ''TOC ERRORa'' AND SWITCHES OFF!
When i insert the mini disc the unit starts as usual displaying all the usual items, then displays ''TOC READ'' makes a dulled clicking noise like hellicopter rotarblades and displays ''TOC ERRORa'' and switches off. Does this mean that the unit is creamed or am i doin something wrong?
regards caicy
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
Disc ejected and then retracted.
Check on the web for the fix. Many people had an issue with the Sony MDS-JE500 series MD units as the little lever switch that indicates that a disc is loaded goes bonkers and it might be as simple as 'adding' a non-sticky item to the lever. Do a Google search for 'mini disc switch fix'. Good luck.
Jan 25, 2014 | Sony MDS-JE520 Mini Disc Player
My MDS-E10 Has Been Having Problems Lately. I Own Hundreds Of Mini Discs That I Have Recorded Music On Several Years Ago. Everything That I Have Recorded On These Mini Discs (Years Ago) Play Fine With No...
hi there is nothing to do by yourself. you need to take your md player to the next authorized service. seems the optical device that reads the discs has worn out, compareable to turntables you need to change the `needle` ;)
Oct 16, 2013 | Sony MDS-E10 Mini Disc Player
Not play toc reading message
If the Table of Contents is read by a disc that is good but the data that follows may not be compatible such as if it was a Mp3 encoded disc.
This was meant for the newer units that have decoders in them.
If you are playing a commercial made pressed disc- this is the kind you use for testing, then your pickup lens may be dirty or the disc is having too much wobble on the spindle. There are a lot of things to check and that is usually done by a technician who knows how to work on disc units.
Mar 24, 2013 | Tascam MD-350 Mini Disc Player
When I try to play my sharp MD-MT15 midi dish player, it did not play. It say TOC ERRORa. Please some one help me to fix it. Thank you very much!!!
That's an ancient player!
Try using a different disc. Try using the external power supply.
User manual http://www.minidisc.org/part_Sharp_MD-MT15+MT16+MT20.html
Mar 26, 2012 | Audio Players & Recorders
How i can fix TOC ERRORa
Table of Contents errors usually happen if you lose power before the disc is 'finalized' when recording. You cannot unplug the unit before it is done with a disc, or remove it until it is done finalizing. You will see "TOC" flash when you are done recording. When it stops, then you are all set. Try a fresh disc and see if that works.
Ive just got a mini disk player and its comeing up toc error,can you help me please
Probably not. There are various reasons that TOC errors occur, some are fixable and others not, but Sharp MD units were really known to suffer from them for multiple reasons all at once. TOC means Table Of Contents; it's an index file on the disc which tells the host machine where everything on the disc is located and the TOC is modified whenever you edit a disc. Sometimes the file gets corrupted, but often the machine itself simply becomes unable to read the disc and as the TOC is the first thing it tries to read then you get a TOC error.
If you're lucky the TOC error is limited to a single minidisc; if this is the case then it's just one faulty disc and although there are ways to perform TOC cloning they usually involve hacking the host machine in various ways which may cause permanent damage. Unless the disc is important, just chuck it away and use a new one. If the fault is with the player then again, just chuck it into the nearest electronic waste recycling bin. Spares are not available, and as it's a Sharp, diagnosis will be difficult and the fault likely to return.
Many MD players are practically worthless these days so they're often available on FreeCycle and Freegle groups: Sony are the preferred choice by far, and are also the most commonly offered brand, but take whatever is on offer without complaint and worry about problems later; after all, they are free.
Mar 03, 2010 | Sharp Audio Players & Recorders
TOC ERRORa
When you FINISH recording, the Minidisc recorder Writes the TOC (Table of Contents) - so you see it flashing TOC or Update when you finish recording - you need to Leave POWER ON and have the unit on for about 30 seconds for it to finish this. IF you don't, the unit doesn't know where to find the files since there is no TOC. Try a Sony home unit - you might get one more shot at it working with that.
Aug 19, 2009 | Sharp MD-MS702 Personal MiniDisc Player
Spontaneous MD erasure
Well, depending how the content was recorded, there may be a slim chance to recover the audio. To me it looks like TOC was not written successfully, effectively deleting the TOC.
You can try TOC cloning with this 'blank' MD using another MD player, but your track markers will be lost during the cloning. If it works, at best you will end up with ONE long track. Then you can edit and reset your track markers.
It may be also be a good idea, to try the JE440 carefully with junk content to make sure it still works ok when writing TOC. You may have an intermittent problem too. I'd be very careful editing MD in this unit until it has been confirmed the TOC writing works ok. You may want to check the over-write head assembly and the cable that connects it. Sometimes these cables develop hairline cracks causing intermittend write action.
Check out www.minidisc.org forum for TOC cloning.
Good luck recovering your audio.
Mar 16, 2009 | Sony MDS-JE440 Mini Disc Player
Sharp MD-MS702 Personal MiniDisc Player Logo
712 people viewed this question
Top Sharp Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
