Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 19hp won't move when in gear
I had to change the tire on my 4 yr old riding mower and after I had this done the mower wouldn't go into gear. It is NOT hydrostatic and the mower worked fine before the tire change. I jacked up the back of the mower and the wheels did turn while in gear but I could stop them with my hand. I checked the drive belt and it seems fine. Can you help me please?
  • french906 May 27, 2009
    Thank You!!! found the key on the ground right where you said it would be...put it back in and the mower works great again!!!
  • french906 May 29, 2009
    Sorry. I am new to this site and wasn't aware of the follow up question. I have fixed it for you. Again thanks for your help.
  • 376 Answers
There is a square key about 2 " long that fits in the slot on the axle and wheel and locks them together.. You probably didn't see it when putting tire back on and knocked it out. If you go back where you removed tire, you'll find it laying on the ground.
Posted on May 27, 2009
  • 2 more comments
  • Dwain Pippen May 29, 2009
    Just wondering why you only rated my solution as "Helpful" instead of a 'Fixya' when it totally solved your problem? It also made my rating percentage go down.
    Thank you! Glad I could help. Dwain
  • Helen Charles Knighton
    Helen Charles Knighton Sep 22, 2012
    The same happened to me when I took off the rear tires. Found one key and put it back in BUT the mower still does not engage in gear. Do both rear tires carry keys? How do I place them ?
    got it working now found the key for the other tire.
Mower will not shift into gear
Please review my answer to:
Craftsman tractor won go into gear had flat tire got it fixed and...
Oct 08, 2016 | Craftsman Garden
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman riding mower that's 2 years old and it won't go into gear it's a 6 speed won't go in reverse either
Hi, did this happen when you went to use it or while mowing? Also will the lever go in but the mower won't move or won't the lever go in either gear at all? Regards Phil.
Aug 17, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
I have a old Snapper riding mower with an 8hp Briggs and Stratton engine, The other day it wouldn't crank so I changed the switch and the solenoid, the battery was fully charged and it still won't...
make sure thers power going into the starter
if there is then see if the starter is siezed, try turning the fly gear, but not just up against the flywheel but try turning the starter backwards to see if it moves
Jul 29, 2011 | Garden
Does a 19hp crasftman lawn tractor have a oil
IF IT HAS AN OIL FILTER IT WILL BE VISABLE FROM THE OUTSIDE OF THE ENGINE. IF THE ENGINE IS A SINGLE CYLINDER IT SHOULD NOT HAVE A FILTER TO THE BEST OF MY KNOLLAGE THEY PUT FILTERS ON THE TWIN CILINDERS
Sep 23, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 20HP , can't stop freewheeling,
Sounds like your problem is the key in your rear wheel is missing or sheared, you have to remove the wheel @ tire assembly ,pull rubber cap off then clip to remove if one of the keys is sheared or gone it will go into gear and the brake will work ,but they will only stop the shaft without the key it will not move or brake becuase its not attached if you know what I mean.
May 11, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
640 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
