Question about Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower 12av5560711183621
Can not engage the direct drive,took gear box apart and found 3 pins loose ,when trying to put pins into the shaft,only one will go in
  • rh_long May 27, 2009
    forget it I just realized what the 3 pins are ,it is 1 shear pin thanks anyway
4 Suggested Answers
SOURCE: Troy Bilt Lawn Mower pull Cord broken
there should be four bolts holding the cover on that houses the pull cord assembly take the bolts out look inside you should see the rest of the broken cord at the other end there is a spool that the cord rolls up in to pull the cord until it stops the other end of the cord is a not in the cord pull on the knot the broken peice should come out turn the spool 2 times in the direction that is against the pressre while holding the spool in place feed the new cord in through the whole that you pulled the broken cord out of then tie the cord in a knot wind the rest of the cord up then feed the other end of the cord through the new pull handle tie the cord in a knot put the housing back on
Posted on Mar 21, 2009
#1 Taper
  • 1040 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: need manual for Troy Bilt lawn mower 12ai867q011
Hi and welcome to FixYa. I am Kelly. You will need both your model and serial number but you can get it online directly from Troy-Bilt here:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1
Just enter your model and serial number and download the manual.
Thanks for choosing FixYa.
Kelly
Posted on Jul 22, 2010
Testimonial: "Thanks"
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Remove self propel gears and axle from Troy bilt push
Most of the self propelled mowers have a pin in them. you need to use a pin punch and a hammer to knock it through. The gears will come off then. Post a picture if need more info.
Sep 02, 2014 | Troy Bilt 5.5hp Self Propelled Mower
HOW TO REPLACE DRIVE CABLE ON TROY BUILT 12A466MO11
Parts Finder Search Results
46 732-1043 Belt Tension Spring open the above link above and zoom in as much as possible on the diagram. Find part #46, which is the belt tension spring. Now locate it on your mower and look at the whole mechanism , where the pulley is. Check to see if it engages when the cable is put put into drive. Order new parts as needed.
May 20, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy-bilt self-propelled won't engage drive
Make sure the drive belt that turns the wheels is in good working order as well. It may have detached.
May 02, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Self propel doesnt work
The cable or spring that engages the S.P. gear box has broken or the belt that drives the wheel has broken.
Good Luck!
Jim
Aug 16, 2011 | Troy Bilt 5.5hp Self Propelled Mower
Have Troy-Bilt lawn tractor (42 in/ 18.5hp), problem is when I put it in forward it does not engage. I think it is the drive belt, which is very loose and worn. Any thoughts
find a small engine repair shop and buy another belt, and a tensioner if it is over 5 years old. Oftentimes it is better to take the old belt with you in case they do not have a listing for your tractor. Before you take anything apart use that cell phone camera for a practical use and lots of pics of the belts. That will save you your next question of how do these belts go back on.
Mar 24, 2011 | Troy Bilt 175HP Manual 42" Riding Mower
How do you remove the gears on a front wheel self propelled troy bilt push mower?
Take the front tires off, pull gears and take out pins, put tires back on and you have a "non-self propell" mower.
Apr 13, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
How do i put a troy-bilt tiller 3 hp.into free
The way to move without the motor running...
1.on each wheel pull pin in center of hub
2.push wheel closer to motor.
3.put pin back in to axle but not though hub
4.do the same steps to other wheel
now you can push tiller
Apr 07, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy Bilt 5.5hp Self Propelled Mower Logo
558 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
