Question about Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas
Side inlets of pool heater are stripped, how do I replace the inlets where the bolts go?
Teledyne laars 250 N the side inlets above the gas connection are strippped, how do you replace the inlets where the bolts go?
    President:
  • 1,489 Answers
The simplest solution is to tap the hole up to the next size bolt. You'll need a small tap & die set, a drill, and the drill bit recommended for that size bolt -- it'll be stamped on the tap.
To accommodate the larger bolt you may have to drill out the holes through which the new bolts are installed -- maybe not.
Posted on May 27, 2009
Gas pool heater model no.lg125p laars lite 2 max.gas preesure 14.
should be between 9 and 10 on front side manifold side should be 3.5
Feb 10, 2013 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Series 2 pool heater just clicks when the heater thermostat is turned on
check to see if voltage on both sides of pressure switch if so see if ignitor is lighting if ok check to see if voltage to gas valve should be 24 volts on each if no voltage check transformer also
Jul 10, 2012 | Teledyne Laars Laars Lx Nat Gas Pool...
Pilot light is on, but heater never engages
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Jun 04, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool heater will not stay lit
Miles
Apr 05, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Teledyne Pool heater flames on for 2 seconds, shuts off
pull out flame sensor and clean with sand paper or emmoring cloth then try again should work (small black wire with sensor sitting above burners)
May 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 125,000 Btu / Propane Gas  Logo
133 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
