Question about Yamaha 12V Air Pump
Excessive smoke coming from waverunner exhaust
After running wave runner while flushing engine with water, there was an excessive amount of smoke pouring out of the exaust on my 1996 yamaha Wave Venture. I use ring free in the fuel and yamalube oil. Any Ideas on what the problem may be?
Is their a trick to putting on exhaust 1998 waverunner xl 1200?
Posted on Aug 23, 2009
    Champion:
  • 207 Answers
Did u leave the water hose running in the ski while it was not running?did this just happen after u ran it at dry dock? have u ran it this year?
Posted on Jul 09, 2009
  • Roid Smith
    Roid Smith Nov 22, 2010
    mine is doing this and yes probably not running all the time I was pumping antifreeze in the water flush hole, what is likely the problem?
What is wrong with my wave runner
Make sure you are using Yamaha oil not an off brand. It does make a difference.
Jul 17, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
How to fix a water port?
possible seized water pump
the one that is not working
follow it back to the source look for blockages
but personally i cannot see a blockage stopping all water coming out
so i would look more at the water pump
Jun 06, 2014 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Water is not coming out my exhaust
reverse flush it were the water should come out put the hose in there.
Nov 06, 2013 | Yamaha Waverunner Xl 700 Xl 760 Xl 1200...
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
1200 yamaha wave runner exhaust light keeps coming on
The exhaust light must be blinking. However, running or operating the engine after the warnings had been activated, the light will continuously on. In this case, cool down the engine b stopping it. otherwise, it may result to a serious damage to the engine.
Jun 09, 2011 | Yamaha 12V Air Pump
03 yahama fx 140 waverunner smoke coming out of water pilots and will only go about 25 to 30 mhp normal is about 60
I was raised on a marina and worked at the waterfront for quite a while. I had wave runners, jet skis, boats, you name it.
Whew, that sounds serious. You probably need to take it to the shop and let them run some test on it. Your problem is bigger than myself.
Apr 11, 2011 | Yamaha Boating
1.9 dci no power and bluey grey smoke is coming from the exhaust
There are indeed traces of oil coming out of the exhaust. Blue smoke is burning oil. Grey or white smoke is usually coolant/water going through the engine. This can be caused by leaking head gaskets, valve guides depending on the engine, excessive blow-by, etc. Large amounts of oil are not good; and water is even worse. I would look at getting the head gasket replaced. The loss of power is because neither oil or water likes to burn, and once your engine clears it out, it probably runs ok for the rest of the day. Then I'm guessing the next morning, it comes back. This is an urgent fix, because prolonged leakage can damage the engine block, head, or both.
Oct 19, 2009 | Renault Sport Cars & Trucks
Yamaha waverunner excessive smoke
White smoke means coolant in the combustion chamber. Most likely a blown head gasket. You will have to tear the engine apart to be sure.
Jul 12, 2009 | Yamaha XS 650 G Motorcycles
1995 yamaha waverunner 3 exhaust leak
pull battery tray and find the broken hoses
Jun 23, 2009 | Yamaha FZ 600 Motorcycles
I just purchased a used 2001 Yamaha XL800 waverunner
Yes. Those are called power valves. The purpose of those valves is they create a variable height on the exhaust ports. This is desirable because it gives you good low RPM power by keeping the height of the exhaust port low, and as the revs of the engine build, the exhaust valves raise up which opens the exhaust port up and allows the engine to create more peak HP due to the higher exhaust port and larger area of the exhaust port.
There is no additive that will clean your power valves. They have to come out.
Apr 06, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
2,800 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
