Question about Brother MFC-210C All-In-One Printer
My printer is saying unable to print
My brother printer is saying unable to print and I have ink in it. what do I do?
  • 51 Answers
Try one or more of these solutions:
  • Press the my printer is saying unable to print - fontp.gif power button to make sure that the printer is on.
  • Turn off the printer and make sure that the power cord is securely plugged in.
  • Make sure that your outlet works and is not controlled by a wall switch or timer
Lights came on and then went out
The printer's voltage may not match the outlet rating. Turn off the printer and unplug it immediately. Then, check the printer labels.
If the voltage does not match, DO NOT PLUG YOUR PRINTER BACK IN. Contact your dealer.
Only the power light is on
  • Turn off the printer and computer. Make sure that the printer's interface cable is securely plugged in.
  • Make sure that there is no packing material in the printer.
  • Turn off the printer and the computer and disconnect the printer's interface cable. Then, print an operation check page. See Running a printer operation check.
If the check page prints correctly, make sure that the printer software and your application are installed correctly.
  • If you are trying to print a large image, your computer may not have enough memory to print. Try printing a smaller image.
  • Windows Me and 98 users can clear any stalled print jobs from the Spool Manager. For instructions, see Using EPSON Spool Manager.
  • If the printer sounds like it is trying to print, but is unable to, run the Head Cleaning utility.
Paper out light is flashing or on Check EPSON Status Monitor 3 (for Windows) or EPSON StatusMonitor (for Macintosh) to find the cause of the error, then try one or more of these solutions:
  • If the fontm1.gif paper out light is on and there is no paper in the printer, load paper into the sheet feeder.
  • If the fonth.gif ink out light is flashing, a low supply of ink is indicated. Obtain a replacement cartridge of the appropriate type. To determine which cartridge requires replacement, see Replacing an Empty Ink Cartridge. my printer is saying unable to print - fonth.gif>
    • If the fonth.gif ink out light is on and the ink cartridge is empty, replace the appropriate ink cartridge. To determine which ink cartridge is empty, see Replacing an Empty Ink Cartridge.
    • my printer is saying unable to print - fontm1.gif steps below.
      r_1.gif Press the fontm1.gif paper button, then remove any paper from the printer. r_2.gif Turn the printer off. Check for and remove any foreign objects or pieces of paper from inside the printer. Also, make sure that there is sufficient space around the vent on the back of the printer to allow proper ventilation. Remove any objects blocking the vent. Then, turn the printer back on
Posted on May 27, 2009
  • 37 Answers
Ideally you need put the machine into "maintenance mode" and find out what error code the machine is giving.
Power off.
Hold down the "menu" button and power on.
Press 8 then 2.
Should give you "machine error xx" (where xx are numbers and/or letters)
This code will mean little (if nothing) to an end user, but means everything to a technician.
In the UK you can ring the Brother helpdesk(0870 830 4000) and they should help you or at the very least tell you what the error refers to.
Posted on Jun 16, 2009
4 Suggested Answers
dutchman05
  • 487 Answers
SOURCE: Clean unable 51
Ok Please follow this link and it has your answer.
Please rate me when it was a FIXYA
Posted on May 03, 2008
  • 583 Answers
SOURCE: Problem with my printer Brother MFC-240C "Print unable 4F"
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart,
try this step by step.without missing any thing. thanks
Posted on Jul 13, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-465CN says 'Unable to Print 5A'
Hi there
Solution:
· Machine off
· Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
· Press 80
· Press the “mono start” button several times until you see “purge: xxxx”
· Press “2783” in order to reset the purge counter. You will see: “purge:0000”
· Press the "stop" button.
· Press “99” to exit the maintenance mode.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
My Brother MFC-215C printer Won't print
1. check to see if you have removed the protective tape that covers the contacts.
2. check to see if you have inadvertently put the cartridges in the wrong sockets.
Apr 22, 2010 | Office Equipment & Supplies
Error message on my printer that says unable to print 36
If this is a Brother clean the clear strip on the carriage assy. it is a timing strip for the carriage , I have seen ink on these cause the "36" code
Jun 05, 2009 | Office Equipment & Supplies
When trying to print it says: unable to clean
refix your ink cartridge then try.also check there is not any paper jam.
Dec 25, 2008 | Brother MFC-3240C All-In-One InkJet...
Clean unable
Follow this LINK and rate me when you are done pls
May 02, 2008 | Brother Multi-Function Center MFC-240C...
Brother MFC 420 CN
the brother printer is not a good brand i also have a brother mfc 3220cn and it gives the same problem, what you have to is unplug the machine and let it stand for about 2 days take out the cartridges and clean the printing with air replace back them and plug in.that should remedy your problem.i urge on you never to buy brother printers.if you buy them get a bottle of phensic along with it.good luck my brother.
Feb 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-210C All-In-One Printer Logo
209 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
