No sound in media player
There is no sound in my system
control panel shows no audio device in volume option
audio shows no playback device
i try to reinstall sound driver throught internet but at the time of running it shows media device not support
i m using compaq presario c702tu notebook
    Problem Solver:
  • 13 Answers
If you go in to your control panel, select sound and audio. Go in to the hardware section at the far right. Double click on the realtec AC/97 audio. Will come up with device disabled, there is a bar at the bottom which says enable. Double click and that should work. Hope this helps
Posted on May 27, 2009
    Problem Solver:
  • 15 Answers
The best will be to start by downloading and installing the chipset drivers for your notebook, which can be downloaded from:
http://downloadmirror.intel.com/13799/eng/ChipUtil.exe
Make sure to restart your machine after installing the chipset.
Secondly download the Audio driver(s) from:
http://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
Install the driver and follow instructions.
Hope that solves your problem?
I have bought creative inspire m4500 4:1 sound box.in reakteck audio manager and control pannel while testing all the soundboxes r responsing.but in any media player two of them isnt responsing..pls help...
Go to Start, control panel, Sound and double left click on Sound. When that opens up it should show a list of your sound devices and which is is set to be the default playback device. You can also change recording and playback volumes here or unmute. Depending which device is set as default the media player should playback on that device.
Dec 09, 2013 | Creative Labs Sound Blaster Live! 5.1...
I am trying to hook the mic up to my computer in the location for microphones and it is not working. i also tried via my tv and stereo system. it will work to receive sounds if plugged into the phones
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 23, 2011 | Samson R31S Microphone
Hy, I have a problem with my mic that is all ready instaled in my laptop also with a camera. When I go to the Control panel to see what is the problem, everything there is ok, but I am not able to work...
There are two separate mic settings in control panel - record and playback. Have you enable record also? See below. Also in Skype-Tools-Options check you have got the right audio device selected (normally WAVE)
Click VOICE
That should be it.
Feb 22, 2011 | Toshiba (P000257700) Microphone
I recently recieved a Bush Noise Cancelling Desktop Microphone M-013NC , i've plugged it into the back of the computer and turned all microphone volume settings upto full, but when i try using the sound...
There are two separate settings in control panel for record and playback. It appears you have playback enabled but not recording - see below
Click VOICE
That should be it.
Feb 21, 2011 | Audio Players & Recorders
New microphone will not record...please advise.
There are two separate settings in control panel for record and playback - see below
Click VOICE
That should be it.
Feb 20, 2011 | Dynex Voice-Certified PC Desktop...
Lm on skype but people cat hear me
You may need to enable your microphone for recording - see below.
Also check in Skype - tools - options - sounds that you have the correct (WAVE) audio source selected
Click VOICE
That should be it.
Feb 19, 2011 | Toshiba (P000257700) Microphone
Media Player No Sound
Do this in steps to insure you are trying the correct solution.
1st) Double Click on My Computer and Double Click on Control Panel.
2nd) Double Click on Sounds and Audio Devices.
3rd) Select Audio tab at the top of the dialog box.
4th) Select Sound playback "Volume button" to check if any options have the mute box checked and if so un-check the box.
This is where to start. after this is done go to the help of the Media player and determine the revision level and include that in the request information.
Good luck for a quick fix.
Oct 19, 2008 | Microsoft Windows Media Player
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Sound driver?
try going to control panel- sounds and audio devices, audio tab, and look for the default playback device.
do you have other options there, besides what it's currently set to?
this is windows xp, correct?
also, on the volume control window, try going to options in the top left, and then properties.
Make certain that you have PLAYBACK selected, not recording, and then make certain that "show the following volume controls" has all the boxes checked.
Mar 29, 2008 | Edirol UA-4FX External Sound System
No Windows Sounds or windows sound functions but All media players work
Select control panel >Sound and audio devices >select Sounds> Sound scheme options check whether the windows default theme is set. if not then set windows default theme.
thank you !
Dec 24, 2007 | Creative Labs Audigy Gamer Sound Card
Computers & Internet Logo
141 people viewed this question
David Payne
David Payne
