Question about iiyama Vision Master Pro 510 22" CRT Monitor
Weird display in the lower corners of the screen the colors are all blurry. it started about a week ago and it just got worst. the default xp windows toolbar is originaly blue and it is turnig greenish. what should i do?
De-gauss the monitor via Menu 4
Posted on Apr 25, 2008
Fix my acer 4315 white screen
Step 1:
Into the Windows 7 Control Panel, locate and open the "Color Management". Open the "Color Management" dialog box, switch to the "Advanced" tab, then click the lower left corner "to change the system defaults.
Subsequently, the system will pop up a dialog "Color Management - System default value again. In this dialog box, the same switch to the "Advanced" option, and then select the check "Use Windows display calibration", after the modification is completed, save the settings and exit.
Step 2:
Step 3:
Step 4:
Step 5:
Step 6:
I hope my answer is helpful to you!
Or wish come If your laptop battery or laptop power supply and adapter notebook hardware understanding or demand
Mar 02, 2013 | Acer Aspire One PC Notebook
My audiovox 32" 3205 died a few weeks ago and took
Not a projection set if 32 inch---If looks like blotches try turning set with it on to see if they change--if so you may have not plugged the degaussing coil (usually a two pin plug) back in when you did the repair--it goes on the power board.
Jun 16, 2012 | Televison & Video
When set on 1280 x 1024 pixels everything looks great but too small for me to read. When I change the setting to 1280 x 800 or lower, words are blurry and taskbar disappears. Can you help?
Which version of Windows are you running? Slightly different between versions, but basically *somewhere* in Control Panel there will be something shown along the lines of Display Options, and somewhere in there will be an option to change Font DPI. (I think XP has a selection of either 80DPI or 120DPI, default is at 80 - Text is much larger and easier to read at 120)
In Windows 7 (and probably Vista) the path is- Start - Control Panel - Appearance and Personalization - Display - "Make text and other items larger or smaller"
Jan 11, 2011 | ViewSonic VG700b 17" LCD Monitor
How do I change resolution on monitor?
that is easy
go to control panel
go to appearance and themes
go to display
go to settings
near bottom is screen resolution select the resolution supported by your video card.
Nov 18, 2009 | HP Compaq WF1907 Monitor
Epson r285 uses all colors to print black
To print in black ink only mode on windows, please follow these steps:
  1. Right-click the drv_taskbaricon_1.gif printer icon in the lower right corner of your screen (taskbar).
  2. Select Printer Settings. A preferences window will appear.
  3. Click the Advanced button in the lower right corner of the preferences window (if you see a Basic button in the lower right corner of the window, skip this step).
  4. Click the Black Ink Only check box.
  5. Click OK in the preferences window.
If you’re using a Macintosh, you can’t set up the printer to print in black by default.
However, your printer will still use minimal amounts of color cartridges to prime the system when your printer is in the initialization stage when turned on. Your printer also mixes all the color cartridges to make up another black, that is to prolong the life of the black cartridges.
Apr 29, 2009 | Epson Office Equipment & Supplies
Windows Vista
What you need is Disable and Turn Off ClearType Fonts in Windows Vista
Windows Vista by default applies ClearType effect to the fonts displayed on screen, in order to improve the appearance of text on certain types of computer display screens, especially LCD flat-panel monitors. As ClearType text actually sacrifices color or chrominance details aspect of image quality for light and dark or luminance detail, some people may not like the blurry font style in ClearType. Here’s a easy way to disable or turn off ClearType in Windows Vista.
1. Right click on any blank spot of desktop, and then select Personalize on pop-up context menu.
2. Select Window Color and Appearance.
3. Click on “Open classic appearance properties for more color options” link located at the bottom of the page.
4. Click on the Effects button.
5. Do one of the following:
Uncheck (untick) the “Use the following method to smooth edges of screen fonts” box.
Select “Standard” to replace ClearType in the drop down list under the above title.
6. Click OK, then click Apply, and finally finish with clicking OK again.
To enable or turn on ClearType effect again, simply reverse the setting in the Effects step.
< Please Rate :) >
Apr 12, 2009 | Compaq Presario R3000 Notebook
Casio Exilim EX-Z60 Start up and screen problem
This is the lens focus gears. They are either knocked out of alignment, or debris has jammed them.
Dec 15, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
How to use buttons on front of Monitor for vertical Horizontal settings
Oldie, The first thing to do is set the monitor resolution, color depth and monitor refresh rate to what you want then adjust the monitor accordingly. Adjust resolution, color depth and refresh rate for Windows 2000/XP: -Right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) experiment with the resolutions and see what you like. -The color quality box should be set to the highest (most colors) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -Typically you would want to set it at 70 Hertz or better. The higher the setting the less flicker you will notice, however, there is always a trade off. I would start with 70 Hertz and gradually move up; at some point your monitor will reach a setting it can?t support. If the screen blanks out Windows will reset back to the previous settings as long as you don?t hit any keys. -click the OK button twice. More to follow?.
Mar 14, 2007 | ViewSonic E790 Monitor
Monitor problem
Melanie, The computers video cards resolution and / or refresh rate is set incorrectly for your monitor. The easiest way to fix this is as follows for Windows 2000 or XP: -While the computer is first starting press the F8 key every second till the Advanced Options Menu appears. -Using the up or down arrow key select the ?Enable VGA Mode? and hit the enter key. -You will be taken to another screen that may or may not have several items to select from. Find your operating system, highlight it and hit the enter key. -Your computer should now load Windows using a generic display mode. Don?t be alarmed if the objects on the screen appear large, this is just temporary. -Log into Windows (if necessary) and you should now see your desktop. -Ignore the popup in the lower right hand part of your screen saying that the display is set very low. Simply right click any clear spot on your desktop and select properties from the menu that appears. -From the Display Properties box that appears click on the Settings tab. -In the screen resolution section (lower left corner) make sure it is set to 1280 x 1024. This is the typical resolution for a 17? LCD but be aware that your monitor will probably be capable of supporting other resolutions. -The color quality box should be set to the highest (most) color setting listed. -Click on the advanced button in the lower right corner. -In the next window click on the monitor tab. -The typical LCD is set to 60 Hertz; however, I have seen where some Acer monitors like 70 Hertz. I would start with 60 for now and change it to 70 if this doesn?t work. -click the OK button twice. -Restart your computer normally and see if it works. Let us know if you have any other questions and please don?t forget to rate this post.
Mar 09, 2007 | Acer AL1716B 17" LCD Monitor
iiyama Vision Master Pro 510 22" CRT Monitor Logo
133 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
