Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Grinding Noise Hi - i have the KitchenAid Ultra Power 300 and have had it for about 12 years with no problems. Today while making batter for banana bread, the mixer started making a terrible grinding noise. The mixer still turns, but makes a horribly loud grinding noise. Any thoughts?
  • 1 more comment
  • red1172 Oct 23, 2007
    Thanks for the solution, however it seemed to be a problem with the motor being loose after 12 years of use.  My husband took the back off the unit and tightened the screws that held the motor in place.  Seemed to do the trick.
  • Anonymous Mar 18, 2014
    Makes a grinding noise
  • Anonymous Mar 28, 2014
    grinding sound when mixer has a heavy load
    Sergeant:
  • 274 Answers
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Posted on Oct 23, 2007
  • Jerry Hess Oct 24, 2007
    That's good news.  With the motor "loose" the gears were not meshing and causing the grinding noise.  It would have torn up the gears if not corrected right away.  That was a stroke of luck.
On low it makes a really loud grinding noise the higher you turn up the speed the slower it becomes.
It sounds like the Worm Gear is going out. The faster the motor runs,
the more damages the Center Gear is grinding away the teeth of the
Worm Gear. Things start to slow down, and eventually they will come
to a halt. It's time to replace the Worm Gear. Also make sure to use
new fresh Kitchenaid Food Grade Grease with the new replacement.
Jun 19, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
My Ultra Series Mixer has started to make a noise so my husband opened it to inspect if there was enough grease and if the gears were worn. There was plenty of grease and the gears were fine. Now that...
the back cover is the housing that protects the speed adjustment! i THINK that this is the reason your mixer is going so slowly but im not sure, you will have to get it checked out by a kitchenaid repair centre seeing as the same thing happened to mine, they told me it was the speed adjustment.
Mar 27, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
I have a 275W Classic Plus, about 5 years old. I've never done any maintenance on it. It gets used several times per week for the basics (banana bread/cake batter, cookie dough) and also at least once a...
There are lots of places to be looking, first thing I would look at would be under the rear cover to make sure the two nuts that hold the rear motor bearing housing in place are nipped up. You don't wring the neck on these nuts, if you over tighten them you will deform the rear bearing housing.
If you can find someone local who has been doing these mixers for a while they will be able to give it a once over. It's unlikely to be expensive. Best people to ask is Kitchen Aid, they should know who does their warranty work in your area. If you are in new Zealand it will be me.
Jun 30, 2017 | KitchenAid K45SS Classic Stand Mixer
Grinding noise
I needed to replace the nylon worm drive in my mixer. When I put it back together, I found that my mixer made a kind of grinding noise. The noise was due to a vibration associated with the cover for the electrical wiring in the back of the mixer. I solved my noise simply by loosening the screw to this cover. The cover is located on the back of the mixer, and the screw is on the top.
Separately, to find instructions for opening your mixer, you can go to http://neilcrockett.com/mixer.htm.
Jan 13, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
My 6qt Kitchenaid stand mixer started making a grinding noise and beater bar keeps stopping. When I put it gently with my finger, it begins turning, only to stop again and make that grinding noise. It is...
They seem to have a plastic gear built in as protection for overloading (prob). When the machine counters to much resistance that gear will strip its teeth causing the machine to not be able to turn, that it what seems to be the grinding problem. If it is not the plastic gear then it another gear that is "stripped(of its "teeth") I hope your problem is not a severe, but if your mixer is "locked up" then at least you found the problem.
Jan 12, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Will a Kitchenaid Pro 500 work in a foreign country with trans.?
Hi, This is not normally a difficult question. Normally the answer would be - Yes no problem. I have taken every kind of appliance overseas. But this particular model has an electronic speed control and finding out the exact details of the electronic clocking is a problem. My best guess is that it will work just fine but at a slightly slower speed like any other 60Hz appliance. Oh and by the way you're gonna need a pretty big transformer this thing pulls 325 watts so you should go to at least a 400 watt transformer for doughs and heavy batter. The thing you could do to find other folks experience is to go to the kitchenaid forum or military wifes forum online and ask if anybody has taken one of these overseas. Good Luck!
Feb 01, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid 600, Stand Mixer - Loud grinding noise, happened when mixing bread dough. When bowl is lowered (dough hook disengaged)....no noise, hook turns. When bowl is raised so that hook engages dough,...
Hi. Stop using your mixer. If your mixer is still covered by warranty, call Kitchenaid Customer Service, they are very good with warranty repairs.
If your mixer is out of warranty, remove the silver band that surrounds the top of mixer. Remove the top cover. At the front of the mixer, locate the transmission housing which is now exposed. Examine this housing carefully for cracks. If you find cracks anywhere in this housing, you have found the under-engineered plastic transmission housing. Kitchenaid's replacement housing is made of metal. Your plastic housing has no business being in a mixer that is marketed as being able to mix bread dough. It cannot!
If you're confident that you can make the repairs yourself, go to the Kitchenaid website and download the parts drawings. Remove the Trans. housing, remove the worm gear shaft assembly which is driven by the motor.. Remove and save as much grease as necessary to thoroughly inspect the worm gear. Inspect the worm shaft bearings. Look for cracks, or missing pieces on the bearings. Look for crunched cogs on all gears. Be prepared to wait at least a month for your parts to arrive after you order them. The replacement grease should be Shell Darina 2, or Chevron FM ALC EP 2.
If you're not confident about repairing this yourself, call Kitchenaid and determine the nearest "approved" repair shop.
You may be able to pressure Kitchenaid to pay for the damaged parts in your mixer. They are still installing these plastic Trans. housing on new mixers. Insist on a metal cover when replacing. Apparently, Kitchenaid feels no shame in their manufacturing process, and will not issue a recall notice for these housings. They are substandard at best.
If you found this solution helpful, please rate it. Good luck! ricardok45.
Jan 31, 2009 | KitchenAid KP2671 Professional 6 Series...
The kitchenaid is making noise and moving
Sounds like the hinge pin may have slid out of half of the base..
Nov 25, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Kitcchen Aid mixer making a grinding noise
common problem. Worm gear & bracket #PS734273 about $36.
Oct 21, 2007 | KitchenAid K45SS Classic Stand Mixer
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
1,924 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
