Question about Sharp AR-5316 Advanced Digital Imager Copier
PERMANENT RED LIGHT pls, the light close to the meter is showing red light. that is the human being shape and the round sign
    President:
  • Sharp Master
  • 990 Answers
Hello sir; Is there have error code display on screen? if not means need periodical service,( need replace drum, cleaning blade, developer etc.).
Posted on May 27, 2009
My 2001 suburban stalls at low speeds or when sitting at red light or stop sign or when turning into driveway or parking spaces or making turns. Is there a fuel idle sensor on this model??
replace the idle air control valve. located on the throtle body that is bolted to the intake. little round cylinder shaped with a wire and plug goin to it!
May 17, 2011 | 2001 Chevrolet Suburban
I have a Nikon FM film camera. The viewfinder has three exposure indicators visible within the viewfield: + for overexposure, O for correct exposure and - for underexposure. These indicators have...
If the red light is steady on the minus sign even if you vary shutter and aperture settings and point the camera at different light exposures, then this is a metering problem. If the red light on the minus sign turns off when you have correct or over exposure, then it would mean your indicator lights for o and + are busted. Have your metering checked by a competent camera technician. In any case, since your camera is fully manual, you can use the 'sunny 16' rule and still shoot away.
Feb 26, 2011 | Nikon Photography
Where do I find the meaning of various lights on the dashboard?
hi, all lights the first and important battery light this shows RED when the alternator NOT carging:
the oil light shows ORANGE LOW on oil:
the engine managment light shows when engine sensors detect faults shaped like an engine ORANGE light
head main beam BLUE when ON MAIN BEAM
indicator FLASHING GREEN light
hazard warning RED light
brake fluid low light RED looks like this ( )
brake handbrake ON RED light looks like this ( )
side light GREEN looks like a star
most of the important lights are RED or ORONGE gerry
Sep 10, 2010 | 2007 Toyota Sienna
Where are the cam sensor and crank sensors located on my car?
Crank Sensor: Passenger side of transmission just to right and above the differential cover. Has 3 wires:
Light Blue/Dark Blue stripe - Signal
Dark Red - 8v supply
Black/Light Blue stripe - Ground
If the car runs or cranks, you can test this sensor by first checking for power on RED wire with key ON. Should be 8-9.5 volts DC. Furthermore, connect a dwell meter to the signal wire by probing the back of the connector. Dwell reading should be 49-51%. If not, its likely bad.
If you remove the sensor, you MUST replace the paper spacer on the end of the sensor or you risk damaging the sensor or even the torque converter drive plate otherwise. Also make sure O-ring is in good shape and positioned properly.
Cam Sensor:
Facing Engine, it is on the driver side timing case housing, on top of the round part, just to the right of the fuel rail pipe where there is a capped fuel valve.
Has 3 wires:
Tan/Yellow stripe - Signal
Testing is same as for Crank Sensor.
May 14, 2009 | 1994 Dodge Intrepid
RED LIGHT
If the signs that is blinking red which is shape like triangle , it is the toner cartridge indicator. The toner cartridge is empty.Try to pullout and check the toner cartridge, if it is light in weight it is already empty.
Feb 23, 2009 | Sharp AR-153E Copier
SLR light meter
Hmmm well its getting power.... surely the lens is on correctly. Since the camera seems to be working, one option is to get a hand-held light meter.
May 19, 2007 | Vivitar V4000 Zoom 35mm SLR Camera
Sharp AR-5316 Advanced Digital Imager Copier Logo
143 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
