Question about HP LaserJet 4250n Printer
`permanent storage full error` what does it mean????
Hp 4250 printer is giving `permanent storage full error` what does it mean?
  • Anonymous Mar 24, 2014
    68.2 permanent storage full
  • 489 Answers
The internal storage system is full. You need to run the HP Web Jetadmin software and delete unnecessary files from the EIO disk device. When done, press the select button on the printer to return it to a ready state. You should be able to print small jobs yet as long as it doesn't require any temporary (or permanent) storage on the EIO disk.
Posted on May 27, 2009
Why is there permanent storage init error?
web search HP laserjet printer error codes
Sep 15, 2015 | HP LaserJet M1005 Printer
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
Apr 04, 2011 | HP LaserJet 2420 Printer
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
My hp 4250 laserjet printer displays an printer error 57.4 message when i switch it on. what could be the problem? since it can not continue the printer checkup progress.
<P><A href="http://www.printertechs.com/tech/error-codes/error-codes-index.php">http://www.printertechs.com/tech/error-codes/error-codes-index.php</A></P><P>&nbsp;</P><P>Plz check the the link for the detail error codes.</P>
Aug 28, 2010 | HP 4250 Monochrome LaserJet Printer
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
HP LaserJet 4250n Printer Logo
889 people viewed this question
Seeker5211
Seeker5211
