20 years in IT and I can't get any FM reception. AM is OK. I bought it for £5 supposedly in working order.
Best wishes,
Martin
http://www.martinhwatson.co.uk/puzzle_news.html
Martin H. Watson
Comments:
May 27, 2009
- Hello, I've got the AM antenna that was provided. There is a socket for an FM coax cable. Shouldn't I still be able to get FM without a dedicated aerial?
Thanks for your help.
Best wishes,
Martin
Martin H. Watson
May 27, 2009
- I've taken one of those long plastic coated aerials off another system. It is like a 'T' with a very long leg. Strangely, it doesn't fit into the coax on the back of the Sony system. It's a gender problem I think, but it seems strange that the coax socket on the back of the Sony is different to the one on the back of the other system. The Sony socket doesn't have a rod or tube inside it.
Best wishes,
Martin
Martin H. Watson
May 27, 2009
- Neither the end of the aerial, nor the Sony socket is threaded. Is there anything here that is suitable:
- Charlie, thanks for that. I've found similar from a UK radio shop, I'll try and get one tomorrow. I've never seen such a thing before. I'm puzzled why the aerial just doesn't plug in.
Thanks for your help, you've brightened up a wet and windy day in London!!
There is hardly ever an internal FM antenna -- only AM. You'll need at least one of those twin-ax dipole antennas (there's one with every receiver bought).
You can test the concept just by putting a single piece of wire on each antenna terminal -- when you do this reception should improve immediately, but will not be as good as with the dipole antenna.
Comments:
May 27, 2009
- You need a 75 ohm coax to 300 ohm twin-ax converter. This will plug into the coax connector on the back and give you two screws to attach the 'T' antenna.
cd player missing piece that holds cd's in place, the piece i assume would be very similar to what...
(More)
cd player missing piece that holds cd's in place, the piece i assume would be very similar to what hold the cd in a cd case....how do i fix that? where can i get replacement parts?
sony cmt-ed1 compact component system, jacks won't work to pick up sound for my sony turntable, any...
(More)
sony cmt-ed1 compact component system, jacks won't work to pick up sound for my sony turntable, any idea how to fix the problem? Neither set of jacks in the back will get sound.
The >> (fast forward) feature to move on to the next song sometimes doesn't work. I tried...
(More)
The >> (fast forward) feature to move on to the next song sometimes doesn't work. I tried cleaning the CD lens reader with a disk cleaner but didn't work.
Thanks!
