EPSON STYLUS PRO 10000 showing error 001001B What is it and how can I correct it? Regards, Mitch.
  • emitchell750 May 27, 2009
    I regret ................ error code is 00001001B and not 001001B as stated. Same problem/error?
    Regards, M
  • 13,433 Answers
Its a service required error code that in most cases will require you to get a repair man out.
looking into the code one possible reason can be a lose connection / wire on the circuit board in the printer head.
but again you will need to help of a repair man to test and find the cause and correct it.
Posted on May 27, 2009
  • Ekse May 27, 2009
    Hey
    the error code has to be 0001001B which is a Head driver (TG) temperature error
    its still a service error code.
Communication error error code :2100012c
Communication error error code :2100012c how to fix
Mar 15, 2013 | Epson Stylus Pro 10000 InkJet Printer
Tip
Epson Stylus pro 10000 Vista x64 Compatible? YES
Use the driver for the next model up: Epson stylus pro 16000.  A 64 bit driver is available for XPx64 on Epson site:  http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=19156&prodoid=22966689&infoType=Downloads&platform=All Install Printer Driver v5.50 in Vista x64.  The 10000 will print 100%, just like in XP with its own drivers.  Any problems?  I would happy to help you save the time I spent before finding that out.
on Apr 05, 2009 | Epson Stylus Pro 10000 InkJet Printer
Tip
Epson Stylus pro Vista x64 Compatible? YES
Epson stylus pro 10000 service request 10015
The error code = Sub Tank Overfill (K) k= Black
Sorrry I do not know how to fix it
Nov 01, 2011 | Epson Stylus Pro 10000 InkJet Printer
Epson 10000 service required?
Hopefully you already have this solved. I had this happen on mine just this last week. The error itself is that the ink level sensor (not the cartridge, but the head) does not detect the correct level of ink. 00030017 is for Magenta specifically. The first step would to make certain there is actually ink in the Magenta cartridge. Physically remove it from the printer and give it a little shake to be sure there is ink in it. Mine had stuck on a nozzle check error and completely exhausted the cartridge.
Dec 01, 2009 | Epson Stylus Pro 10000 InkJet Printer
Does it work with mac OS X 10.5.6
Check this page on the Epson website:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=14366&prodoid=4742585&infoType=Downloads&platform=Macintosh Good luck!
Apr 25, 2009 | Epson Stylus Pro 10000 InkJet Printer
Epson stylus pro10000 problem service reg
SERVICE REQ. 00020000:NVRAM ERROR
SERVICE REQ. 00020001:NVRAM COMPARISON ERROR
SERVICE REQ. 00020002:SDRAM ERROR
SERVICE REQ. 00020003:FLASH MEMORY ERROR
Problem
Abnormal detection in a corresponding element
Solution
1. Once save parameter to Flash memory card and install it to the printer again.
2. C362DRV board. replacement
Feb 18, 2009 | Epson Stylus Pro 10000 InkJet Printer
00010014 Pressurization error
Ink supply pressure incorrect
Explanation
The pressure system is determined to be leaking then this message appears and printer is stopped when detection of pressure origin sensor is incorrect at power on initialization or ink supply.
Solution
1. Replace supply pump assembly (including pressure origin sensor solenoid).
2. Check for disconnected air tube.
Aug 30, 2008 | Epson Stylus Pro 10600 InkJet Printer
Epson error code 0104
00000104 Auto print head optimization system is all the manual says. No solution given.
Apr 01, 2008 | Epson Stylus Pro 10000 InkJet Printer
224 people viewed this question
jasbo
jasbo
