Question about Microsoft Xbox 360 Console
Xbox360 elite cannot connect to xbox live because of my ips/router but can connect to wireless and internet.and it has come up with the number 3074 what does all this mean can u please help me thanks.
  • xjerseyx May 11, 2010
    Yes, 3074 is a port you need to open. Do you have a router? I need to know the current setup you have and I will be able to fix it for you.
  • 34 Answers
Contact the router company have them walk u through make sure these ports are open
If you have not already forwarded ports for your xbox through your router then that may be your problem.
The following ports must be available to your Xbox 360 console for Xbox LIVE to operate correctly:
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Posted on Jul 19, 2009
    • Neen39 Aug 13, 2009
      sounds like ir router doesnt have the proper ports open to support xbox u need to call xbox find out what ports need to be open then call ur router company and they will help u open the right ones so it will work
    Xbox360 live setup
    You need to forward these ports on both your router, and computer aswell as firewall you got one of those.
    • Port 88 (UDP)
    • Port 3074 (UDP and TCP)
    • Port 53 (UDP and TCP)
    • Port 80 (TCP)
    You might aswell need to open 1863 (UDP and TCP) if you want to use video chat for the kinect.
    Listed ports need to be forwarded when connecting to XBOX Live
    A more detailed guide to setting it up is available here: http://support.xbox.com/en-us/xbox-360/networking/network-ports-used-xbox-live
    Nov 15, 2013 | Netopia 2247NWG-VGx Wireless Router...
    My Zonet ZSR4134WE Wireless-N router doesn't connect to live. I've checked the MTU setting and everything. It works perfectly, until it gets to the "Xbox Live" part of the test, then it fails. Please help.
    you need to open the ports on your router for xbox ports are TCP 88 UDP 88 UDP 3074 TCP 3074 UDP 53 TCP 53
    first connect the xbox to the network and get the ip address (like 192.168.x.x) and then use the computer and login to router setup page and under firewall open these ports for the ip address of xbox . If you find a DMZ there , then enable it for XBOX ip address and reboot the router. ** imp: try to make a static ip address on xbox so when you restart the xbox teh ip address should not change -
    to check what is the ip address provided from you router :- go command prompt (start ->run- > type cmd and hit enter) a black screen(command) type ipconfig you will find ip address of computer , so you can set the ip address of xbox like that -but just make the last number different (like ip address on computer 192.168.2.5 then make ip address of xbox to 192.168.2.6) perform this will help .. its all about the ports but be sure with ip address
    Oct 01, 2010 | Zonet ZSR4134WE Wireless Router
    Can't get on line
    If you are using an access point or a router to get onto the internet you have to ensure that the unit has been set to accept the Xbox 360 as an authorized unit.
    Jul 10, 2009 | Microsoft Xbox 360 Console
    How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
    Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to http://192.168.1.1 username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Jun 30, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    Netgear DG834G with xbox360
    Connect to the Router,
    Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
    Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
    Mar 02, 2009 | NetGear DG834G Router
    My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
    hi,
    in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
    for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
    Dec 29, 2008 | Linksys WRT160N Wireless Router
    Xbox360 elite
    do u have a router and if so u need to make sure these ports are open
    • TCP 80
    • UDP 88
    • UDP 3074
    • TCP 3074
    • UDP 53
    • TCP 53
    Jun 14, 2008 | RCA Thomson Digital Cable Modem (DCM305R)
    Xbox360
    Hello taz1028,
    In order for you to be able to log into Xbox Live, you will need to have DSL or Broad Band internet connect in your home. Once you have that, you will be able to connect the Xbox 360 directly to the Modem that the internet provider gives you. If you wish to able to connect both the Xbox and your notebook to the modem you will then need a router or a wireless router. So, if you do not have DSL or Broad Band Internet service in your home, you will not be able to log into Xbox Live.
    Sincerely,
    Agent Xiong
    May 31, 2008 | Microsoft Xbox 360 Elite Console
    Optimizing WGR614(v1) for xbox live
    the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
    Sep 28, 2007 | NetGear WGR614 Wireless Router
    XBOX 360 Elite problem
    You're routers are not compatible
    Jul 09, 2007 | Microsoft Xbox 360 Console
    Microsoft Xbox 360 Console Logo
    147 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
