Question about Panasonic NV-MX500B Mini DV Digital Camcorder
Panasonic NV-MX 500B stored for a year now won't work
The camera was working fine, didn't use it for 12 months and when I came to use it again it would not work. I sent it to a Panasonic repair center and they told me it would cost £750 to repair. The camera was little used and has had no problems before. I cannot understand it needing such an expensive repair, can you advise me please?
  • 1 more comment
  • james_mandev May 27, 2009
    Thanks for your answer. I'll have a look at it and see if the semiconductor fuse has broken. Cheaper than replacing the MPCB.
    Do you know what the product code for the semiconductor is? I can't find it on the service manual schematic.
  • james_mandev May 28, 2009
    Do you know the part number for the fuse and where I can get hold of one?
    Problem Solver:
  • 16 Answers
If you didn't used it for long time as 1year you must have to replace a new battery with clened battery connectors.1st you should' ve try to operated it with the charger.If it doesn't work still,high current drain during the first attempt caussed broken semiconductor fuse in side the main P.C.B.Some repairmen used to replace M.P.C.B. without repairing it.
that's may be cost a lot for you.
Posted on May 27, 2009
  • filmico Nov 13, 2010
    Got the very same problem. Is anywhere in the world a repairman who can fix this broken semiconductor fuse without replacing the M.P.C.B? I goth 3 cameras "dead" that way, Changing the M.P.C.B costs several hundreds euros only for the spare part!
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic NV-DS30. Camera and VCR works only at
i had same problem and i took out the tape cartridge and found tape hanging out i fixed that carefully then it worked fine
Sep 08, 2009 | Panasonic Video Cameras
LCD screen goes blank on my Panasonic NV-GS17 camcorder
you need to replace your camara's flex cable (LCD HINGES-technical name).
Jun 02, 2009 | Panasonic NV-GS17 Mini DV Digital...
VCR function not working on Panasonic NV-GS3 DV camera.
Hello tlofterroed, What it sounds like is there is a formatting error. What i would suggest is updating your software and trying it again. If this is not the case please write back and i would gladly help.
Please post what you do and how you did it I look forward to your posts
Nov 11, 2008 | Panasonic NV-GS3B Mini DV Digital...
Panasonic NV-GS27
try fire wire,read on another forum that this has worked for some1 else
Jan 02, 2008 | Panasonic NV-GS25 Mini DV Digital...
F02 error in Panasonic vedio camera
Hello.
F02 error code means tape slack. If you have a separate deck try winding the tape all the way to the end and then rewind it back to get the tension up. Or if you are able to do it in the camcorder then do it this way.
Nov 30, 2007 | Panasonic NV-VX77 Camcorder
How to reset the camcorder if the reset button will not reset it.
...and try this first...:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
Jul 14, 2007 | Panasonic PV-GS39 Mini DV Digital...
Open Questions:
Panasonic NV-MX500B Mini DV Digital Camcorder Logo
209 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
