Power locks just kept unlocking and locking . took it to garage and they told me its a part that's in the dash behind radio and it's costly . can anyone help ?please
SOURCE: FORD RADIO ON LOCKED 13
if that is not an anti-theft radio... or if it is an you know the code and how to enter it.... unhook the battery for about 15 minutes and then hook it back up again... that should reset it
SOURCE: 2003 ford escape, fuse keeps blowing for door locks, radio and dome light. y
check for a shorted to ground positive wire repair as nesseacry
SOURCE: remote fob and power lock buttons wont unlock or
Unless the batteries on your key have run flat and need replacement, the key needs reprogramming. Advanced diagnostics at an authorised service centre will sort both issues pretty fast.
SOURCE: power door locks move but won't lock/unlock
I had this problem with the door locks also and it was the door look accuators were striped out. Most locking accuators use a type of motor gear which is plastic. Over time the plastic becomes hard and the teeth break off. You can get these new or used on ebay or get some aftermarket accuators from a car alarm installer. Hope this helps. Terence
