Question about Hayward SAND FILTER, PRO SERIES
Pool need to know how hoses hook to pool
  • Samuel Charles Spriggs May 11, 2010
    Is this a filter for an above ground pool? Does the filter have its own pump or is the pump separate from the filter?
    Champion:
  • 246 Answers
From the skimmer to inlet pump -from outlet pump to in let filter -from out let filter back to pool return
Posted on Aug 25, 2009
How do you hook up a hydrotool model #72712 to an above ground pool
in of pump to skimmer out of pump to intake of filter out of filter should be return or to pool that goes to pool return other hose is for backwash
May 25, 2016 | Swimline Hydrotools Sand Filter
How dose pump hook to pool? where do i get hoses and conecters
go to the hardware store and get barb fittings that fit the threads to your filter and they also sell flex hose or pool hoses
Jul 27, 2014 | Intex Pool & Spa
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
Hose hook ups
If you look at the chlorinator you'll see an arrow pointing in the direction of the flow. Basically the water coming out of the pool should be going through the filter tower first and then through the chlorinator and ultimately back into the pool.
Jun 16, 2010 | Intex Automatic Salt Water System for ...
Hooking up five hoses to my hayward pump/filter
Your system has a suction side and a discharge side. Skimmer and bottom drain hook to the suction side. Returns (discharge) return via chlorinator or other sanitary system and heater if appropriate, to ports in the side of the pool.
May 31, 2010 | Hayward SAND FILTER, PRO SERIES
Use of pool vacuum
Try consulting the owners manual for these pool filters for more info. I can tell you that you need to have your valve set to rinse for normal vaccuming and waste for heavily soiled pools. Hope this helps.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 04, 2010 | Hayward SAND FILTER, PRO SERIES
How do I hook up an aqua chem pool vacuum for an above ground pool?
i need to know the same thing,I hooked everything up as it looked right but no suction?I hooked the 1-1/4 hose to the vinyl liner vac. head then hooked the other end to my intake hole wich sucks into my filter,but i notice the filter water is not circulating properly,the filter itself is drained of water? will this burn it out or what?
Jul 18, 2009 | Vacuums
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
3-Tier Henry Fountain Problem
the best thing to do is this bucket of water plug in pump put hose from pump in water to find out whats in and out. out hooks to top in hooks to bottom
Jan 23, 2009 | Henri Studios Henri Studio 5215f17 Three...
Hayward SAND FILTER, PRO SERIES Logo
520 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
