Question about Gigabyte 8I845PE-RZ (GA-8I845PE-RZ) Motherboard
Re bios booting problem
Thanks ebay312 for your reply. its true. even me im not convince that its a mother board since i got some display in my monitor even a few seconds only. yes the system is shutdown while checking the memory test and sometimes it wont reach in memory test & its shutting down. its runs only around 5 to 10 seconds. the ram i have was also check from other pc as well as my cpu and its works. the confusion for me is that the mother board of my friend is not the same which i have
4 pcs of cpu i already installed one at the time in my board but they have the same symptoms. its really amazing this kind of problem my ram is 256mb at 266 bus speed. is it compatible for my board ? do u have idea how you can reload the software of my bios. Is there any pins do i need to short in order to prevent the open case sensor in the mother board. i hope that you will give me more help regrading about my problem. swordfish
  • Art Ellison
    Art Ellison May 11, 2010
    You've started a new question--since I didn't see the first one, you'll have to help me out here.
    If I understand you, your computer will not start completely?
    Sounds like it is shutting down during the memory test. Is this true?
    How about telling me the brand and model of your motherboard?
    Novelist:
    Champion:
  • 256 Answers
Sir; I need a recap from you. You talk about one computer or many. We are only to help the final consumer and his advisor. You have gone to the CPU and took it out of socket? Do you have any special heat conducting grease to apply? Don't turn on the computer until you replace the heat transfer compound from the CPU Chip to the heat sink. Your CPU may commit suicide because of you. Anyway, I have one trick that you should check. Bypass the AC switch, not just the button, but bypass the AC, so that the Power Supply has 110 VAC all the time. There is a protection in the low voltage switch button, that, at times it false triggers (or there is a need to shut off because of an overload). When you turn on the computer, stand by with your hand on the plug to pull it, since the idea is to avoid burning up the Power Supply. If this does not work, get back to me but, please, with more descrete information. Thank you for considering our service...
My name is Constantin (arzconst)
Posted on Jun 01, 2009
Pci express will not work
Your N9600GT provides two HDMI out puts for dual display.
Even though you are currently only using one HDMI. Switch your monitor cable to the other HDMI out put. See if you now have display.
Also while in the bios allow, Page 2-27 in manual, Allocate IRQ to PCI set to [Yes]. Page 2-24, Internal Graphics Mode Select, [Disable]
Luck!
Mike
Oct 07, 2009 | ASUS P5GZ-MX Motherboard
D865GVHZ mother board Doesnt boots
If everything was working fine before, and you flashed bios unsuccessfully, then yes, if would be a bios problem.
If you didn't flash the bios you should check the connections on your monitor. If that's okay then check your memory, hard drive and cpu.
Good luck,
Hank
Aug 17, 2009 | Intel D865GVHZ Motherboard
Bios booting problem
Something is definately not right, but I am not convinced it is the motherboard.
You are saying the system shuts down while doing a memory test? I would replace the memory with known good, and known compatible with the system first.
Also double check the cpu and cooling system to be sure the cpu is not burning up.
good luck
tony
May 22, 2009 | Gigabyte 8I845PE-RZ (GA-8I845PE-RZ)...
1. On board display card is not working 2. When we attach external vga card display is working but no BIOS image in mother board and it gives an error that BIOS image is scan. 3.Key board is not working.
who makes the mother board and what bios is it using? can u access the bios at boot up? if so, is the integrated video option on? have you checked for upgrades / updates for the bios ? if you can access the bios, remove all non integrated devices from the mother board, select the option for "default settings" save and exit. then restart. after assuring the keyboard is plugged in the correct port. it should be color coded.
May 19, 2009 | Gigabyte GA-K8VM800M Motherboard
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
On board ethernet driver conflict with windows XP
go to the bios settings & there you can disable the onboard LAN ....
so by this you will be able to boot from your hard drive ....
you can go to the bios settings by pressing F2 (or delete key in some PC s ) at the time of the booting (before the OS loads)...
there in bios settings just search for the LAN device & disable it ...
that s all your problem will be solved ....
any doubts reply me
i am always here to assist you
thank you
bye
rate my solution as per your satisfaction
Jul 05, 2008 | ASUS P4C800-E Deluxe Motherboard
NO BIOS
to get bios set up you must press DELETE key or F2 to enter set up...
you do this at the time of the booting ....
if your bios is corrupted then you can restore the bios by changing the bios jumper to restoration mode to do this refer to your motherboard manual...
Feb 22, 2008 | Intel Motherboard
Please Tell me, ASUS P4S8X-MX Problemn
First of all, try to reseat all the cables inside your computer just make sure there aren't any loose connections.
If that doesn't work you will have to reset your BIOS. (Follow the instructions in your motherboard manual.)
If even after resetting the BIOS the problem is not solved, you may have to replace your CMOS Battery.
Oct 18, 2007 | ASUS P4S8X-MX Motherboard
Montherboard in troble poor response from the dealer
Dear Rajamoni,
please confirm that which selection u select after pressing F8.
If u select Safe mode (top option) and your system running normal in safe mode. Then the problem in your monitor refresh rate settings...under display properties(desktop-rightclick-properties-settings-advance-adaptor-list all modes-800x600 16bit 60Hz) apply all settings .your system may be normal.
regards
Prabhat
Lucknow
india
Oct 13, 2007 | ASUS P5RD1-VM Motherboard
Gigabyte 8I845PE-RZ (GA-8I845PE-RZ) Motherboard Logo
99 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
