Question about GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator
Ice maker only makes crushed ice, no cubes I have the same problem... The same switch works fine for the crushed ice and water setting but will not dispense cubed ice. It only gives crushed.
    Sergeant:
  • 296 Answers
Hi.
I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck.
chek these sites
http://forum.appliancepartspros.com/refrigerator-freezer-repair/23620-ice-maker-only-makes-crushed-ice-no-cubes.html
There is an opening next to the auger that dispenses the ice. In there there is a lever that must move up and down. It actually seats the metal rod on the bottom of the ice maker and controls cube or crushed. Make sure the lever is down (cube position) when you return the basket to the freezer. I had to hold it down while I slid the rod into the opening. Cubes again. http://www.applianceblog.com/mainforums/showthread.php?t=783
if satisfied plz rate this answer
all the best
regards
Posted on May 27, 2009
    President:
  • 1,489 Answers
There is a solenoid which mechanicaly switches the ice dispensing mechanism between crushed/cubed. This solenoid is either bad or jammed or has bad electrical contacts.
  • 184 Answers
SOURCE: Ice dispenser only dispenses crushed ice
THE WAY A DISPENSER CHANGES FROM CUBES TO CRUSHED ICE IS BY RAISING AN ARM THAT RUNS ALONG THE BOTTOM OF THE ICE BIN. IF IT SETS FOR A LONG TIME, IT CAN GET A BUILUP OF FROST OR ICE THAT KEEPS IT FROM MOVING. PULL THE ICE BIN OUT AND TRY TWISTING THE END OF THE ARM MANUALLY. IT SHOULD OPEN A DOOR AT THE FRONT OF THE BIN THAT WOULD ALLOW THE ICE TO BYPASS THE CUTTER ASSEMBLY.
ALSO,WITH THE ICE BIN REMOVED, PUSH THE DOOR SWITCH BUTTON CLOSED BUT KEEP THE FREEZER DOOR OPEN. WHERE THAT ARM GOES IN THROUGH THE BACK WALL, CHECK FOR MOVEMENT OF A ROD UPWARD WHEN YOU CALL FOR CUBED ICE. IF YOU HEAR A LOUD HUM BUT THE ROD DOESN'T MOVE, YOU MAY NEED TO REPLACE THE SOLENOID ASSEMBLY IN THAT MODULE.
Posted on Apr 10, 2008
  • 142 Answers
SOURCE: water dispenser on front of refrigerator door does not dispense water. Ice Cube maker continues to make ice cubes. Defrosting doesn't fix problem.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
Posted on Jun 02, 2009
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Posted on Jul 30, 2009
woodchuck789
  • 4059 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
My ice maker does not make ice but water does run to front of fridge plz Help ????
I can't make out the words in your picture so there is not a lot of information to go on, but I will give it a try. If yours is like my refridgerator, there are a couple of off switches for the ice maker. One is on the control panel like the one you tried to photograph. Mine selects crushed ice, cubed ice, or ice off. The other soff switch is the lever switch that sits over the ice cube reservoir inside the freezer and shuts off the ice maker when the reservoir is full. If this lever switch is stuck in the up position you will make no ice. You say that water runs out of the front. Another problem that I once had with my ice maker was that the plastic housing around the ice cube tray cracked. One tray of ice cubes was made but when the ice maker flipped the tray over to expel the ice cubes the cracked plastic prevented any torque on the tray and the ice cubes would not come out. When the tray returned to the upright position new water would flow onto the tray, but since it was already full of ice cubes the water would simply overflow into the ice bucket reservoir. It did this over and over until I had an ice sculpture in my freezer and reservoir instead of ice cubes.
Jan 02, 2017 | Refrigerators
Ice maker dispenses crushed ice in the cube setting. Water and crushed ice are fine.
Typical of a switch failure / control module failure so it sticks on the crushed ice setting or the crushing mechanism is u/s and wont turn off. Call a service engineer asap.
Aug 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not dispensing ice
If the dispensor light switches to cubed or crushed , the panel is good . Remove the ice bin , and hold the light switch in . Press the arm for CRUSHED ice , and if you hear a buzzing or hum , then the auger motor is frozen . Use a hair dryer directly on the " forks " for a while , ocasionally holding switch and activating arm , until the forks move . Lower the freezer temp slightly and reinstall the ice bin .
Aug 11, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Ice Maker frost and freeze where ice drops into refrigerator door
You need a service guy to look at it. It could be water leaking or a simple case that the flap isnt sealing and the ice melts and then freezes the flap open
May 14, 2009 | U-Line CO2075F-B Echelon Refrigerator Ice...
Apr 17, 2009 | Refrigerators
Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Jan 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Side by Side Model #TFH24PRSMWW Ice maker
The on and off switch of the ice maker on the ge side by side model has fell off and appears broken. please instruct with a diagram how to reattach.
Oct 20, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
hi there,
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
GE GSS20IEPWW / GSS20IEPCC Side by Side Refrigerator Logo
1,255 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
