Question about Freezers
Ocean upright freezer
My problem with my ocean freezer afc740. When I switch it on the red light comes on, and a sound of a motor, but this only lasts for a few seconds. The green light never comes on, and the yellow light comes on when i put it to boost with the same motor sound, but i have never noticed a drop in temperature.
textonor
  • 130 Answers
SOURCE: Whirlpool upright freezer AFG823NF-Thermostat not working properly
JennyT just trying to help with this. I assume this is a self defrost model. If so then is there an ice build up on the back wall? If so then the unit isn't defrosting. That is why pushing the Fast Freeze button is no longer working. You can get by however. Remove all the food from the freezer, put a vacumn in the freezer and shut the door. Turn on the vacumn, this will pull the warm air thru the freezer and in 30 minutes to an hour it will be defrosted enough to work until you can get someone to replace the 1 of 3 parts that the defrost system uses. The vacumn is what I use to defrost my nonself defrosting freezer. Sorry I couldn't be of more help.
Posted on Feb 03, 2008
SOURCE: Upright Frigidaire Freezer
The Amber light is the Power 'On' indicator. The Red light is a Temperature Alarm indicator. THe Red light comes on if the freezer compartment rises above 20 degrees F (for example a freezer malfunction or someone left the door open). You also probably have a rocker switch (or two holes that are over a rocker switch) that is in between these two indicators. If you do, that's an audible (loud buzzer) alarm when the red light comes on. The rocker switch is a simple on-off switch to silence the alarm or turn it back on.
Posted on Jul 12, 2008
SOURCE: flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Posted on Aug 20, 2008
rockitman187
  • 2559 Answers
SOURCE: Can a freezer be operated in temperatures below freezing.
Yes,It will work just as it should.
Please rate this a fixya
Posted on May 18, 2009
  • 103 Answers
SOURCE: Whining sound from motor on Frigidaire upright freezer
Hi: It sounds like you bought a frost free freezer as it has a fan. The fan will come on to circulate the air. It will not necessarly run continuosly. The noise is most likely coming from the fan. I sold Frigidaire freezers for years and they are noisy compared to a refridgerator. If you think it is louder than it was when you bought it, I would replace the circulating fan. Also look at the back wall for frost as it could be a bad defrost heater blocking it with ice. Most likely just the fan though. Since it's in a detached garage,and you won't have to put up with the noise inside your house, it could run a while before failing. The fact it's getting cold is a very good sign.Also as you asked 2'nd, a freezer is ok in an unheated garage. Don't put a refrigerator in there. Unless It is a Whirlpoll Gladiator that is designed for such applications. Use www.searspartsdirect.com to find out where the fan is if you feel it is necessary to replace it. Its not a tough job if you are handy. Their shipping is expensive so you might want to buy it locally.
Posted on Jun 22, 2009
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
Jan 01, 2016 | Kenmore Freezers
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Ocean Frost Free dial keeps going inro Red/Black & we have no Manual
Hi clarry441,
I would like to clarify if what is the brand, type and model name of your unit?
Thank you for using FixYa.
Jun 27, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Things are defrosting. Red light on bottom right side is one. When I turn on the on/off switch a buzzer/alarm sounds. Is this freezer dead?
It may be a malfunction causing this.
Check for ice buildup on the lower panel inside the freezer.
This will be a sign off a failed defrost component.
Check the fan motor in the freezer,is it running?
If not,that can be a problem.
Feel the compressor,is it running?If not,that can be a problem.
Jun 29, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The red light is staying on and i can hear the motor ocean upright frezzer frost free ffc780
Check the condenser fan. Clean the coils. Report your findings. It the compressor hot? If so check the relay.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 05, 2010 | Freezers
Kenmore upright freezer no digtal light no motor running
if it is an electronic control freezer then the electronic control sounds as though it has failed if there is no digital read out
May 02, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Red light on
The red light and the audible alarm both come on when the freezer gets warmer than the alarm point... unless you disable the audible alarm with the rocker switch
Nov 24, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
Jul 07, 2008 | Frigidaire 20.6 cu. ft. / 583 liter...
The buzzer is loud
Frigidaire # LFFH2067DoW2 # WB52430831 upright freezer (frost free commercial)
Freezer is still freezing. The alarm sounded and I switched the switch off to turn off. The manual says that the temperature isn't at the right temperature and once it reaches the correct freezing temperature the light will come back on or the sound would go off after at least 4 hours. This was since last night about 6:00 and if i switch the switch the alarm is still sounding. The left side of the freezer is a little warmer than usual. Any suggestions
Mar 02, 2008 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezers Logo
759 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Freezer Expert? Answer questions, earn points and help others
