Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool Fridge and Freezer quit cooling properly at the same time.
I have a Whirlpool Refidgerator/Freezer. The were bought neww 3 years ago. Friday I got in the Freezer and my icecream was soft, I assumed the door was not closed tight ( I have kids. I made sure the door was closed and went to bed. Saturday the fridge was still working fine, icecream still soft. Sunday both fridge and freezer not working. The food is hot. There is a motor running, I pulled it out and cleaned everything real good, and turned temp to the coldest on both. What should I do? My Whirlpool refrigerator/freezer also quit cooling in a very similar way on Monday, May 26, 2009. The model number of my fridge is ED5CHQXKQ00, Type 25SSA. It's about 8 years old. There is a fan still running, however neither the refrigerator or freezer sides cool to lower than 57F despite having the controls set to the coldest positions.
    Problem Solver:
  • 18 Answers
You likely have a defrost system problem.....call a service company to look at it.
Posted on May 29, 2009
Defrost heater do not defrost creating poor air circulation
for starter call viking with your mod and ser #
there is a hinge recall on fridge door is covered by warranty regardless of age
it can cause the air channel from freezer to fridge to ice over due to too much humidity entering fridge
this stops cooling in fridge
the viking warranty starts from the day you took possession
defrost heater almost never
sounds like you need a better servicer
ask viking for other auth servicer in your area
gl
Apr 07, 2017 | Viking DFBB363L (20.3 cu. ft.)...
My whirlpool reftrigertor side by side, fridge side is hot and the seals are extremely hot. I just bought it today at a tag sale, it is only a year oldm, what can the problem be?
If the cooling is OK specially in the freezer and the fridge, then you need not have to worry on much. If there is no cooling then the unit must be checked for failure in the sealed unit.
However you can select a NORMAL thermostat setting for the fridge /.freezer , set it lower than the present settings. Also check and see if the unit had the panels removed, if so the insulation of the heat exchange coils could have come off and it might be heating the side metal wall of the fridge.
The heating of the coil is quite normal as due to the heat exchange needed for the cooling.
Jul 28, 2011 | Whirlpool Refrigerators
Whirlpool Gold GB2SHTXTS00, I bought it in 2007, but 3 days ago, the cooling suddenly is not working, but freezer and lights are fine
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
May 06, 2011 | Whirlpool Gold Series GB2SHTXTS (219 cu...
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Both Fridge and Freezer quit working properly at the same time.
I will need the model number as shown in photo below where the locations are most likely to be. While I am waiting I am going to go over some models like yours to see what may possibly be wrong.
http://servicepartstec.blogspot.com/e6dabfb.gif
May 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge and freezer not cold enough since we moved
remove the panel at the reaar of the freezer. you should have a full frost pattern on your evaporator (frosted not snow packed) and the fan should be running. if you do not have a full frost pattern then you have a sealed system leak. covered under the first five years of your warranty
Feb 17, 2008 | Whirlpool ED5SHAXM Side by Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
795 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
