Question about Canon imageRUNNER 3300 All-In-One Laser Printer
E000733-0001 the err means I have the same problem, the same error code: E000733-0001 on my Canon IR3100CN. I cannot pass to service mode...After I switch off & on, the display shows me the same error...Please, need help!
  • sridharsa23 May 11, 2010
    Error Code : E000733-0001 on iR 5000
    President:
  • 1,126 Answers
E733-0001 Error Code
E733 and machine locks up with progress bar at 98% on boot up?
I would refer this error to a qualified service Tech.
Deals with replacing DC controller, Main Controller and Boot Rom as a set. Also, mention of replacing the Switching Regulator PCB Assembly if the previous failed to resolve.
Posted on Jun 03, 2009
  • Copytech
    Copytech Sep 24, 2017
    Actually I'm facing this problem I've already changed DC, mfc, and reader... Not helped... Tell me a solution
Solution off error code 000002 off IR 3245 Canon ?
Hi. That error means there was a temperature error . You need to enter into service mode to clear that error.
with the copier powered on press the next secuence
press adittional function once
press 2 and 8 at the same time once
press adittional function once again.
service mode should appear in the screen. If it doesn't. Repeat the procedure.
with service mode in the screen :
select COPIER.
Select FUNCTION
Select CLEAR
in the list below select ERR and press ok in the lower corner of the screen .
turn off from the main switch of the machine for about 10 seconds.
power on the machine and make some copies .
if problem persist that mean that fixing heater is defective and need to be replaced
Feb 26, 2018 | Canon Office Equipment & Supplies
Error codeE000-001
him that error mean there is temperature error. you need to clear that error from service mode first.
press aditional function
select COPIER / FUNCTION / CLEAR / ERR and press OK
disconnect the machine for 5 seconds
turn the machine on and make some copy test
Feb 15, 2016 | Canon IR3570 COPIER FOR 220 VOLTS ONLY
How to correct this error E0000040010
Dear
In service mode do in service mode
(COPIER >FUNCTION > CLEAR > ERR).
this may solve the problem. The code is due to the irregular supply to heater assembly. If J303 at DC-CON board is opened then the code may display.
Thanks.
Feb 02, 2015 | Canon Imagerunner 5055 Digital Copier
Error code E00000-0001
That error mean there is a sudden change in the fixing unit temperature.
First clear that error from service mode. Press additional function
press 2 and 8 together
press additional function agian
service mode should appear in screen
select copier
select function
select "clear"
select "err"
select ok.
unplug power cord for a few seconds and restart the machine
try to make some copies if problem persist replace the fixing heater assembly
May 29, 2014 | Canon imageRUNNER C5180 Color Copier
Canon ir5075 error code E00014-000
ese are all list of error code in Canon iR5075
  • n cause: the main thermistor (TH1) has poor contact or an open circuit.The thermal switch (TP1) has an open circuit.The fixing heater has an open circuit.The SSR is faulty.The DC controller PCB faulty.Mode of detection: 0000 after the main power switch is turned on,the temperature detected by the main thermistor does not reach 70?C.
Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
  • E001
Main cause: The main thermistor (TH1) has a short circuit.The sub thermistor (TH2) has detected overheating.The SSR is faulty.The DC controller PCB is faulty.Mode of detection:0001 The main thermistor or the sub thermistor has detected about 230?C or higher for 2 sec.0002 The main thermistor has detected 230?C or higher (hard circuit detection)0003 The sub thermistor has detected about 236?C or higher. Caution: The error must be be reset in service mode (COPIER>FUNCTION>CLEAR>ERR)
Dec 12, 2013 | Canon imageRUNNER 3300 All-In-One Laser...
Error code e000004 0401
1. Make the following selections in sequence to perform the error clear:
[Service mode > COPIER > Function > CLEAR > ERR].
2. Turn the control panel switch OFF > turn the main power switch OFF/ON.
3. If the error code still persists, check to see if the connector [1] of the fixing thermo switch is disconnected or the pin [2] of the receiving side connector is bent. If the connector is disconnected, re-fit it.
Jul 29, 2013 | Canon imageRUNNER iR C4080 Color Copier
Canon Ir2318 error code 00003
the code is related to the fuser section.If the machine is new then enter the service mode by pressing additional function and then * and clear it in error clear , if it is old machine then check the fuser for open thermistor,broken element .
Aug 24, 2011 | Canon imageRUNNER 2200
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
Error code E00001-002
the sub thermistor detect 295 degre celces or higher the couse will be the fixing fillm unit is foulti (that is the thermistor is short circuit the main power suplay is foultiy the dc controler pcb may foultiy to clire the error you have to go copier -function-clear -err from the service mode , to inter the service mode * and pres 2and 8 key simultinusley and then*
May 20, 2010 | Canon imageRUNNER 2200
Canon imageRUNNER 3300 All-In-One Laser Printer Logo
2,122 people viewed this question
old marine
old marine
