Question about Canon PC-D340 All-In-One Laser Printer
Problem system error E000 with canon PC-D340 all-in-one
I need copy with scanner but my machine his coming (system error E000)
please help me
SOURCE: cannon image class D880 System Error E000
Option 2 worked like a charm! Thank you.
Posted on Mar 09, 2009
  • 150 Answers
SOURCE: canon d760 system error e000
I used your "Best solution" and it worked
Thank you,Steven
Posted on Mar 04, 2008
vmhreha
  • 77 Answers
SOURCE: System error E000
E000 is a high temp. error. My first advice would be to atempt to clear it in service mode:
  1. Press ADDITIONAL FUNCTIONS, #
  2. Go to #7 Printer and press OK
  3. Go to #4 Printer Reset and press OK
  4. Yes = ( * )
  5. Power cycle unit.
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
Posted on May 28, 2008
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
Posted on Mar 31, 2009
  • 4 Answers
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
How to fix cannon pc-D340 system e000 error code
Hi . That error indicates there is a malfunction in the fixing unit. The fixing heater may be damaged and need to be replaced
Sep 27, 2016 | Cannon Office Equipment & Supplies
Help me how to remove system error cod e000 for canon pc-d 340
PC-D320/PC-D340/FAX-L400 Chapter 4: Maintenance and Service
E000 Fixing unit failure
Cause: (1) Shorted/broken wired main thermistor (2) Shorted/broken wired sub thermistor (3) Broken wired heater/blown thermal fuse
Solutions: (1) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-2 (FSRTH) and J206-1 (GND). If the resistance is not within the range between 350 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (2) Turn the power off and remove the fixing unit from the machine. Measure the resistance between the fixing unit connector J206-3 (FSRTH2) and J206-4 (+3.3V). If the resistance is not within the range between 370 KW and 520 KW (room temperature of 20°C), replace the fixing film unit. (3) With the fixing film unit removed, if there is no continuity between the fixing unit connectors J102-1 (ACH) and J102-2 (ACN), replace the fixing film unit. (4) Replace the ECNT board. (5) Replace the SCNT board
See Service Manual page 105 (4-25):
Canon PC D320 Service Manual Page 105
Jun 04, 2015 | Canon PC-D340 All-In-One Laser Printer
Systemerror E100
That means that you have laser unit related error.Probablly bad laser controller pcb.
Jun 01, 2010 | Canon PC-D340 All-In-One Laser Printer
SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
May 29, 2010 | Office Equipment & Supplies
The Screen on Canon Image Runner says E000 - can't make copies
Your Fuser just went , Call you Canon independent or Authrized dealer, he will need to go into the simulation to reset this error. Usually E000 is either a fuser or fuser web error. I'll need to look this up in the service manual. most likely you'll need a quailify technician to reset this error code.
Mar 04, 2009 | Office Equipment & Supplies
E000 sYSTEM eRROR
Solution: Unplug unit for 3-5 minutes, then plug the unit back in
Unplug unit for 3-5 minutes, then plug the unit back in.
OR
I hope it helps!!!
Dec 12, 2008 | Canon ImageClass MF5770 Laser Copier...
Error Message - System Error E000
Does a page come out? just blank? How old is your cartridge, did you pull the tape out? Need more info to help.
Aug 28, 2007 | Canon imageCLASS D860 All-In-One Laser...
How do i get rid of e000 system error?
is the fuser unit getting hot as it should be?
Jun 06, 2007 | Canon imageRUNNER 1210 Copier
Canon PC-D340 All-In-One Laser Printer Logo
444 people viewed this question
old marine
old marine
