Question about Fujitsu Siemens Premium Line P15-1 15" LCD Monitor
Fujitsu-Siemens P15 TFT power/picture problem. it take time to turn on.
My monitor has recently developed a problem when being turned on. The power light flashes orange in a steady rhythm (approx 1 second on, 1 second off, repeat) and no picture whatsoever appears. The PC boots normally, I can "guesstimate" the user login location for WinXP on the welcome screen, and sometimes can hear the startup noise through the TFT speakers (very faintly as the light pulses on). I have tried 2 AC Leads, 2 analogue cables and my DVI-D cable as alternate inputs, and the mainboard graphics too, but still no signal. The monitor usually puts up a grey box saying "No Signal - Entering Sleep Mode" when no signal is detected, but this has not appeared. A second monitor on the same graphics card, with the same cables shows a picture, as it does on the mainboard Graphics card. Sometimes, I can jiggle the leads in their sockets, and eventually (after many hours) it appears to solve whatever the problem is (or just wishful thinking after hours of frustration), and return the picture. Sometimes when this happens, it is a normal start/power-up sequence, but sometimes the screen is totally whited-out, and I have to cycle the power to get a "waxy", striped effect which disappears from top to bottom as the real picture appears. Any help or ideas would be welcome, but for the meantime, I'm having to buy a new TFT tomorrow, as leaving this one on 24/7 to prevent the problems and frustration, is not really a long-term solution. Thanks. When i turn on my LCD its blink the orange light and automatically turn off and there is no any picture appears just a dark screen this process continued for few minutes and then it appears the screen, something I diagnose the problem that in the cool whether and atmosphere it take much time to turn on rather then worm atmosphere, might be its capacitors are not working correctly but not shore. Can you help me to overcome this problem?
  • johny_mic99 May 28, 2009
    its not a better solution to buy a new LCD i think there is manegemetn failur just monitoring to the production not quality.
  • 52 Answers
It does indeed sounds like the capacitors, I had this problem last year with a Medion monitor where it would turn on and off, when I spoke to Medion they did say that it would need a repair but at the time I wasn't enclined to pay the repair fees for something that may happen again!
Personally I would stick with your plan of getting a new monitor because my view on monitor hardware issues is that if it's happened once it will happen again even if you do repair it resulting in a lot of hassle!
Posted on May 27, 2009
2 Suggested Answers
SOURCE: Fujitsu-Siemens P15 TFT power/picture problem.
i have problem too
Posted on Sep 23, 2008
OSD locked
OSD MAIN CONTROLS REMAIN UNLOCKED ON MONITOR 170A PHILIPS SERIAL NO AU 015240
Nov 24, 2012 | Fujitsu Siemens Premium Line P15-1 15" LCD...
There is a problem in LCD, when become ON so start flickering continuously
Need more information. Does it switch on / off intermittently or the screen brightness is varying ? Refit / Replace signal cable.
Samir.
Feb 07, 2011 | Fujitsu Siemens Premium Line P15-1 15" LCD...
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Dec 12, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Fujitsu Siemens Premium Line P17-1 17" LCD Monitor. When the monitor is turned on, you can see the Fujitsu Siemens logo for half a second, then the screen goes black. (LED stays on) The monitor...
Monitor ia having a problem with Voltage filtration... Replace the electrolitic capacitors at secondary side of power board, There are 2 voltages, 12 V and 5V...each of them has few electrolitic capacitors in line, replace them, watch the polarity and all works...Cause of eletrolitic capacitors on secondary side may be the one little capacitor in the primary side, becarefull there is some high voltage out there
Dec 11, 2010 | Fujitsu Siemens Siemens Premium Line P17-1...
Screen colour suddenly gone wrong colour ie dull and blue tinted, not sure what model number but it is a 19inch 1
It sounds like the video cable plugs are not seated properly or bent pins, please check that out first, also try it with another PC to make sure it is not the PC video card problem.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Sep 10, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
It happens at random maybe after turned on for a couple of days, maybe after a couple of hours. More than three quaters of the screen just goes black, the other bit is still working fine.
Inspect the caps in the power supply and solder joints.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
http://www.badcaps.net
Jun 13, 2010 | Fujitsu Siemens Premium Line P15-1 15" LCD...
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
My fujitsu lifebook e7010 doesnt always turn on properly
If an external monitor is plugged in an the display is ok then the problem is probably an inverter board or bad/loose flex cable to the lcd screen.
If the external display is distorted then the problem is the video adapter on the laptop.
Mar 31, 2008 | Fujitsu LifeBook E7010 Notebook
Fujitsu Siemens Premium Line P15-1 15" LCD Monitor Logo
406 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
