Question about GE Spacemaker JVM1640SJ Microwave Oven
Read the question
Need to know what side the power cord comes out of spacesaver microwave,so I can cut out upper cabnit for electrical box, I think it's on thr right side of spacesaver,just double checking,Thank you!
Dear FixYa:
Just to let you know, I'm a general contractor in the state of michigan.And after I didn't hear from you
I just made a phone call to reasure myself on my question, because it's been a while since I installed
kitchen cabnits.Almost every spacesaver cord is located on righthand side.
Posted on May 28, 2009
Where is the reset button located on spacesaver micro wave oven
  • locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
  • Mar 24, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
    I think the fuse is blown on my emerson microwave mw8781sb i test the power coming from the plug and there is power but none after that
    You have blown the microwave internal fuse. If you are handy enough you can take the cover off and follow the power cord in the system. The fuse will be between the transformer and the power cord
    YOU MUST DISCONNECT POWER CORD AS PART OF ELECTRICAL SAFETY WHILE WORKINGON ON THE SYSTEM!!
    Sep 27, 2011 | Emerson MW8102SS 1100 Watts Microwave Oven
    How do you check/change the fuse in the microwave?
    You will need to remove the cover which opens from sides and pull it up. Follow where power cord comes in and before it get tothe transformer,there will be a fuse.
    YOU MUST DISCONNECT POWER AS PART OF YOUR ELECTRICAL SAFETY!!!
    Sep 22, 2011 | Emerson MW8107WA Microwave Oven
    We have had custom cabinets made for our kitchen and have installed a microwave above the stove and it is to high for my wife, She is 5'4" tall and can hardly see in the micro wave. The carpenter doesn't...
    you will also need to consider space between the stove & microwave, but you could go back to your cabinet company and have them make you a dead panel that matches your cabinets for the face side of the microwave. then you will also need three other pieces 1 for each side and 1 for the back! if you want to drop the microwave down 12 inches have your panels cut 12 inches! have your carpenter block in and attach panels, go to a fastner company with 1 of the bolts that the microwave came with to hang it from the cabnit and find or order bolts the compensate for the depth in which you you have your panels built!
    May 31, 2009 | Microwave Ovens
    Heat doesn't come on in microwave
    If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capacitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. For part go to www.partselect.com and enter your model number. If you found any of these suggestions helpful, please rate my solution. D. Lange
    May 01, 2009 | Microwave Ovens
    GE Spacesave died
    Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
    Microwave Oven Basic Troubleshooting Tips
    heatman101
    dyjd
    Apr 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
    GE Spacesaver XL JVM1341WW002 microwave broken door handle!
    Its a free country Bage, but microwave energy is extremely dangerous! Repairs are not feasible unless performed by factory personnel under warrantry, and certified. I suggest you contact the manufacturer about the problem.
    Ray
    Nov 19, 2008 | GE JVM2050 Microwave Oven
    GE Spacesaver microwave question
    A microwave should always be on its own breaker to prevent the breaker's being tripped. If that happens too often it can wear out the breaker and/or the outlet. But that won't damage your magnetron.
    I would say one of three parts has failed, the high voltage rectifier diode, the magnetron, or the high voltage transformer.
    Here are some links you or someone you know can use for testing (in order given) for test help, but read the safety warnings first:
    http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
    http://www.gallawa.com/microtech/mag_test.html
    http://www.gallawa.com/microtech/xformer.html
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    If it's the magnetron, and it's within the magnetron portion of the warranty (usually 5-9 years) but out of the original full warranty (usually 1 year), then your manufacturer will cover the part cost, but not the cost to visit you or the labor charge to do the work.
    Some manufacturers will send you the magnetron to do it yourself. If nothing else, you can save about $75 by taking it to the shop yourself.
    If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
    You can download GE owner's manuals and installation instructions here.
    Oct 21, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
    My General Electric Spacesaver Microwave is not rotating and makes a clicking noise instead.
    You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
    If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
    To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Jul 17, 2008 | Microwave Ovens
    GE Spacesaver microwave trips the circuit breaker
    Since power = voltage X current, 1.58kW / 120VAC = 13.166A
    So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
    Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
    Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
    A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
    If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
    If it passes this test, the problem is likely in the microwave.
    Jan 09, 2008 | GE JVM1190 Microwave Oven
    GE Spacemaker JVM1640SJ Microwave Oven Logo
    55 people viewed this question
    Top GE Microwave Ovens Experts
    D. E. Hev
     Larry
    Larry
    Shekar Avadhani
    Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
