Question about Sony SDM M51 15.1" LCD Monitor
Brightness There is no brightness at all just a very dull image. Any clues
  • awfishbay Jun 19, 2008
    I am unable to brighten the image on the screen. I go to the menu for screen brightness but cannot adjust the brightness (which is only 35%).
  • 4,889 Answers
Looks like your contrast is set to very low...just adjust it..
Posted on Oct 21, 2007
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
The projector is not giving a bright picture. The image on the wall is very dim
I you were using the projector in the same room with the same ambient light and if you notice this problem try increasing brightness, if still the brightness is not sufficient then it is time to replace the projector lamp.
If you have moved your projector to a different place, check if the existing light / ambient light in that room is making the image look dull / not so bright. If this is the case, try to reduce the ambient light
Mar 09, 2011 | Dell 1100MP Multimedia Projector
The picture on my monitor is blurred n dull n d brightness cant b adjusted!
Monitor issue is not a Barcode Scanner problem.
Now then...go to your control panel/hardware and sound/display.
There should be options to change brightness and resolution as well.
Blurred issue you might want to make the resolution higher.
Brightness issue, manually change the brightness from your video options where I have stated at the first.
Aug 22, 2010 | Computers & Internet
Leapster 2 screen to dull to see
The leapster 2 screen is so dull you can hardly see the writing and programs. Very dark in colour. You can see colour arounf the edge of screen but the darkness overpowers the screen.
Jun 06, 2010 | LeapFrog Leapster 2 Learning System
Ihave a sony KDF-E50A10 and the picture is fading
check the lamp timer in the menu page of the projector.it it is more than 1500 hours, it can be the lamp
alternativly u may also check the optical engine as it may be covered with dusty , hence resulting in dull images
Feb 06, 2009 | Sony (XL-2400) Projector Lamp for...
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
I've acer travelmate 4500 laptop. Till yesterday it was working fine, but today i donno what happend to it.. the screen display is completely dull. that I couldn't see the display and if I closely observe...
The possible reasons is that you have turned down your brightness and contrast without realizing it, to fix this simply look for a brightness key on your keyboard and turn it up. If it is missing or did not fully work, see if you can notice any image and try to get into your Display properties, click the setting tab and go into advanced and turn up your brightness and contrast from there. If this does not work, im afraid to say you have damaged your LCD screen and this would result in your dull screen appearance. Get a computer technician to take a good look at it to see what has happened if this is the case
Hope This Helps
Nov 18, 2008 | Acer Computers & Internet
Screen`s brightness less
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Sony SDM M51 15.1" LCD Monitor Logo
96 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
