Question about Thetford Porta Potti
Casset toilet will not pump water for flush
Toilet will not flush, could this be a fuse? if so where is it?
    Sniper:
  • 61 Answers
Open door, remove toilet cassette unit, look in under flush water tank, observe a short metal blade that actuates a safety switch. This is between two plastic guides. Now look just outside the right hand guide. There you will find the fuse which is a standard blade type. Just pull it down to remove from holder. You will probably find it rated at 3 amp. If it is blown you will probably have to replace pump. Looks difficult but is actually dead easy. Instructions come with replacement Thetford pump. Only problem you may have is a perished sealing ring on the paper holder cup which is no longer available as a spare. Just use a good quality outdoor type sealant as a replacement. Be sure to recover any bits of broken ring from the flush water tank as these can be drawn into your replacement pump and cause it to sieze. At minimum this will cause you to say bother! Happy repairing.
Posted on Jun 13, 2009
  • 1 more comment
  • p_t_r_thomps Aug 05, 2011
    fantasic, advise very helpfull and fixed our problem,
    THANK YOU x
  • hluczka
    hluczka Jul 08, 2013
    check the fuse but still not working any other help????PLEASE...
  • JohnLong Jul 08, 2013
    There are several possible causes of failure to operate when the fuse is good.
    The easy one is a low battery voltage - just try putting the battery on charge. Usually everything else seems to be working fine but these pumps are not happy if the battery voltage is a little low.
    The next action to take is to check the wiring continuity. Regret I can't be specific about this because caravan wiring differs from model to model and sometimes from year to year. Try to locate the low voltage distribution terminal blocks and make sure all connections are good. Make sure that none of the wiring has its insulation trapped inside the terminal block under the terminal screw. You may be able to trace the wiring to the PortaPotty by the colour of the wiring insulation. If not try disconnecting each terminal in turn to see what stops working. If nothing else stops you have probably found the correct wiring and should be able to inspect it up to the PortaPotty fuse. If you have the use of a multimeter you will be able to check the wiring and pump for continuity. It is equally important to check the return wiring from the other side of the pump to ensure that this is connected to the other battery terminal. The return may be by a terminal bolted to the caravan chassis so make sure that this is not corroded - alloy chassis are particularly prone to develop a thin protective oxide layer. This should be cleaned off under the terminal and an electrically conductive grease used to prevent further corrosion. Copper Ease is probably as good as any.
    Good hunting.
Why does my toilet belch water after flushing
Always the first thing with bad toilets. Take a big plunger and pump hard covering the entire bottom of the bowl. Blockages cause air breaks which cause the belching
Mar 19, 2014 | Computers & Internet
Toilet won't flush...seems like no power
hi i have a thetford casset toilet but my flusher is not working i have cheked fuses but i am stumped now please help
Oct 18, 2011 | Thetford Porta Potti
Toilet flushes by its self
Water pressure makes the unit kick on and off by itself. If the pump is turning on by itself that means that somehow water is draining into the pump creating enough water pressure that it will make it kick on and off. Inspect the flapper on the check valve inside the discharge elbow, also check the flapper on the flush valve inside the toilet tank, the flapper may not be closing properly and is allowing water to enter the pump.
Oct 11, 2010 | American Standard Colony 2388.012.222...
Saniflow pump keeps comming on without flushing toilet
Water pressure makes the unit kick on and off. If it's turning on by itself then most likely somehow water is draining back into the pump. It could be leaking water from the toilet tank, to the bowl and from the bowl to the pump. Or the check valve inside the discharge elbow may not be closing all the way down and is allowing waste water to drain back into the pump creating enough water pressure that makes the pump kick on and off. Inspect the flapper on the flush valve and the check valve on the discharge elbow on top of the macerating pump.
Aug 22, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
How do I know if the macerator is working if I flush the toilet I acn hear the pump start and see the 22mm outlet pipe vibrating as water is pumped thru it. But I'm not sure if macerator is working. Does...
If you flush the toilet at least 3 times and water does not back up on the toilet then is working. In case the pump fails the pump will fill up about 3 to 4 gallons of water before it overflows or backs up. You can also try disconnecting the discharge pipe off the discharge elbow and place a bucket at the end of the discharge elbow and flush the toilet into the bucket, if water is discharged into the bucket then is working properly.
Jul 20, 2010 | Saniflo & Saniplus& Macerator Pump
My Saniflo sanicompact does not flush away, when i press the flush botton it does not work, the toilet buzzes all the time. when the water gets to a level it use to pump away but has stoped doing this.
saniflo buzzing all the time means that the motor is trying to run but cannot. indicates that something is blocking the pump impeller from rotating. unit needs to be removed, cleared and tested. if fault contiues you may blow the fuse (if you are lucky) otherwise the motor will eventually burn out. get this checked soon.
Apr 12, 2010 | Saniflo Sanicompact Elite - One Piece...
Toilet flushing sytem
your chain on your flapper is to long,adjust to proper hight.
Jul 15, 2009 | Kohler Santa Rosa K-3323-0 White Compact...
Grinder wont turn and toilet not flushing
Disconnect the power and pull the pump out and examine the pump. Simple and easy!
May 23, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Toilet pumps bursts of water
either your fill valve needs replaced or your flush valve needs replaced
May 13, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Thetford Porta Potti  Logo
2,551 people viewed this question
Top Thetford Camping, Backpacking & Hiking Experts
Fredrik Str?hle
Fredrik Str?hle
Level 1 Expert
Tony
Tom Chichester
Are you a Thetford Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
