If bumps affect the noise then you should be looking at loose wires and connections for the speakers and at the back of the system. Look for a bad earth or the earth wire connected up to something that is not really a good earth
Testimonial: "thanks alot for the tip bud , ive been trying to figure it out for a while now , i hope i can solve the problem ,"
SOURCE: heater blower motor works intermittently
I would replace the blower motor, this sounds like a motor brush problem inside the motor itself.
SOURCE: 2002 Grand am gt monsoon, hook up rear aftermarket speakers
You have to test them, either should work fine (as in use either pair) if that doesn't work connect one pair at a time and listen for the difference, one pair might be for factory midrange and other for tweeter.. there are two different wiring configurations...
SOURCE: wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
