Question about Hitachi 42PD3000 42 in. Plasma Television
T V Goes on to Green Light Yet Box Stays On Red
The box and TV is all pluged in both are on standby yet only TV goes green and box stays on Red I Need An ENGLISH COMPANY
I have an AV3000E that developed this symptom following a 5 second power cut.
I downloaded the manul, suspecting a power supply problem. The way the AV3000E works is to have a 5 volt power supply running all the time, this powers the main processor. The main processor then energises a relay (S901) by applying 5V DC between relay pins 3 and 4. The relay contacts switch rectified mains power to the main switching regulator. The replay was being energised but appeared not to be switching. While the AV3000E was connected to the mains, I carefully I connected a short between relay contacts (1 and 2) while the processor was trying to energise the relay coil. The TV burst into life. I removed the short and the TV continued to operate normally and has done so ever since. I cannot entirely rationalise why this has worked as this should not have fixed the relay, what may have happened is that the short power cut may have resulted on the some corruption of the processor non-volatile memory, and that the incorrect operation of the main relay caused the processor to reset it's internal memory.
BE WARNED, WHAT I DID WAS EXTREEMLY DANGEROUS AS THE RELAY CONTACTS I SHORTED ARE CONNECTED TO THE MAINS SUPLY - YOU ARE LIKELY TO KILL YOURSELF IF YOU DO NOT KNOW WHAT YOU ARE DOING - PLUS I TOOK THIS ROUTE AFTER ELIMINATING THE OTHER OBVIOUS PROBLEMS LIKE FAILED FUSES.
Posted on Jul 04, 2009
Converter box will not stay on - starts green light then switches to red
I have one of those right here attached to my computer so I can watch TV on the PC. The red-green light is the power indicator. Your converter is turning off for some reason. Possibly it is getting a signal from another remote, and turning off. You can block the converter's remote sensor with something (black tape works) and then change the channels with front panel buttons if it has them.
Mine has power buttons for both the TV and the converter, so watch out for that.
Apr 06, 2017 | Televison & Video
We have a 2007 Sony Bravia 46" KDL-46VL130. There is not sound or picture. When we power it on the green light comes on blinking once and then the red light blinking once and then the green light stays on....
Does the front light stays green ? Or goes back to red ? The back-light going on/off maybe the problem, but it shoul return with a red blinking led (4 times ?) and if so it can be a power inverter problem.
Oct 09, 2013 | Sony Bravia KDL-46VL130 TV
Why did my Kolin DLT-3212M LCD tv picture suddenly go green
Are you connected with a box of some kind via the component input on this set? (red, green, blue connections?
If so unplug that box and wait--plug it back to see if the box will reboot and correct the issue--also you can try to swap green cable itself with blue for example and if then have BLUE issue that cable is bad.
May 20, 2012 | Televison & Video
My t.v is stuck on standby, the green on light comes on for two seconds then goes off, and the t.v just stays black, but the red standby light stays on.
are you sure that all the cables are hooked in? most hdtvs will go into standby if there is no signal coming from the input.
Feb 28, 2011 | Toshiba REGZA 32RV530 31.6 in. LCD HDTV
My LG Plasma 42PC3D turns on and off repeatedly. I turn on my FIOS set top box first and than the TV and it turns on and off repeatedly (front bottom display goes red and green, red and green repeatedly)....
Your plasma TV has a power supply 6709900019A. These power supplies failed due to defective capacitors. See the picture below and check the capacitors mark with the red lines. There are 10 capacitors that should be replaced even if they do not show signs of bulging/swelling on top.
The value of the capacitors is 3300uF/10V but you can use 25 volts as long as they fit in the space provided by design.
Sep 24, 2010 | LG 42PC3D 42 in. Plasma Television
My thomson dti 6300 250gb free view box wont turn on
Emailed Topuptv and got this reply
Dear Sir/Madam,
Thank you for contacting Top Up TV.
Please note that we are currently aware of an issue affecting some Thomson DTi6300 boxes.
If your DTR will not come out of standby and is not responding to your remote control, please try the following procedures.
Step 1: Power cycle
First of all, remove the power to the box and wait 20 seconds before restoring power.
Wait while the box tries to restart and allow 2 -3 minutes for this to complete.
Try this at least twice.
If it doesn't go to the solid green light then proceed to the next step.
Step 2: Front Panel Reset
Note: This procedure will unfortunately cause you to lose all of the recordings that you have stored on the box. You will need to be able access the back of the DTR and the front panel buttons
1. Remove power to the unit by removing the power cable from the back of the DTR.
2. Wait 20 seconds and restore the power cable while holding in the standby/power on button on the front panel of the DTR.
3. Release the standby button immediately you see a light 'blip' on the DTR front display and then immediately press the following front panel arrow buttons in sequence Up>Down>Left>Right
4.The DTR will now show the Orange LED with the Green LED flashing until the format has been completed in about 60 seconds. The DTR will return to ON automatically.
5. If requested, perform a channel scan to complete the operation.
We apologise for any inconvenience caused. Our Customer Services department can also be contacted on 08444 159 159. However, please note that we are currently experiencing high call volumes and so may not be able to answer your call as quickly as we would like.
Kind Regards,
Richard
May 04, 2009 | Televison & Video
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
Tv sound and pic goes out and green light flashes for 38 seconds
I have the same tv and it did the same thing. I replaced my lamp and it corrected the problem.
Jan 25, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Red and green flashing boxes, will not turn "on".
the epromm chip on the mainboard needs to be change
Mar 22, 2008 | Pioneer PDP-425CMX 42 in. Plasma...
Hitachi 42PD3000 42 in. Plasma Television Logo
494 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
