Question about Car Audio & Video
No sound from the speakers
I have a sony xplod system on my pontoon. The radio would not work and I found a 10 amp fuse on the back side of the radio was bad, replaced it and the radio now comes on but there is not any sound. It will take a tape(CD) but there is not any sound.
  • 87 Answers
The main thing on problems like this are the speakers, either grounded out or the voice coil is bad. Being on the water it is subject to way more moisture. I would suggest disconnecting all the speakers and either tiring them one by one to see if they function or "pop" them with a 9 volt battery.
OR you can cut 1 speaker at a time from the wire harness at the back of the radio to see if the stereo comes back on. (goes into protection mode when a speaker grounds out)
If that all fails then the deck may be done ---- more than likley one of the speakers though.
Posted on Jun 02, 2009
Sony xplod stereo wiring diagram
Yes you need to turn on the BOSE amplifier in the car to hear the sound. The wiring diagram is actually on top of the factory radio
You will need a 12v trigger to turn the amp on. this is assuming you have all the speaker (inputs) connected to the output from your new deck.
Sep 09, 2013 | 2001 Audi TT
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
I have a 800W Sony Xplod amp and two Jensen 10 inch speakers, when i turn my car on no music comes from the two speakers. Every couple of seconds the sub clicks with the beat of the music, nut it still has...
I think' its preamp problem inside your power amp, maybe its an IC,transistor. also try your radio to other amp' if ok,, the problem is your amp... bring to the nearest qualified technicians..
Aug 10, 2011 | Audio Players & Recorders
I have a Sony Xplod 800w Amp running a 10' Sony Xplod Amp....i unhooked the amp to do some moving and i tried to put it back in today and it didnt have any sound coming from it! I did notice the power...
it sounds like it could be a blown channel in the amp. if the sub was blown it would still work just sound horrible. i have blown many subs and amps. you can bring it to an audio shop near you and they can fix it. i just got one of my channels fixed for 35$
May 11, 2011 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have 2 10' sony xplodes connected to a 2
If your radio is still playing and the subs are giving you music, you most likely have the amp remote wire hooked to a constant power source on the radio. Generally, this is a solid blue wire on both the radio and the wiring harness. It allows the radio to turn the amp on and off when the radio is on or, subsequently, off.
Apr 21, 2010 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony Xplod Amp
well you might want to try using 30 amp atc fuses instead of 10 amp fuses on your amp, because you are getting an overcurrent from your alternator then from your battery. I have the same amp and you will find that your subbs will hit better too. also check on your ground wire from your amp as this also will cause the RED light to come on. :)
Mar 24, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Hi i have a 600 watt sony xplod amp model xm-554zr and it recently stopped working. when i turn my car on the amp turns on but only for a sec then the protection light comes on, on the amp and it wont...
sounds like maybe a speaker short, try unhooking your speakers and then powering up your amp, if it then powers up with the speakers unhooked try hooking up each speaker one by one untill the amp goes back into protection and then you have your bad speaker.
Mar 08, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
