Question about Designjet Black Designjet 30/130 Series Training: Color Management in Adobe Photoshop (q6650a)
Error code 96:11
Hi, we have a designjet 30/130 which has come up with an 86:11 error code. We've tried turning it off & on, the cutter and carriage move freely and are in the right place all ink cartridges and print heads are present and correct and the carriage door is properly attached. It was in the middle of printing when it suddently stopped and hasn't worked since. Is there anything else you can suggest? Many thanks
    Problem Solver:
  • 5 Answers
Due to its special nature, the scratch pool should not be directly targeted by any policy. Ensure that all policies and schedules specify a volume pool other than the scratch pool; then run the job again.
Posted on May 27, 2009
Paper cutter
You should try replacing the cutter assembly with a new one. They are rather inexpensive ($50) to purchase and easy to install.
The only other thing I can think would cause your problem is if something is stuck in the groove by the cutter guide that would cause it to disengage while cutting.
Jun 07, 2013 | HP DesignJet 500 InkJet Printer
Can't find cutter. could it have fallen into machine. the clip that holds it is there. This happened after trying to clear a paper jam
Cutter unit having press & release system, by mistake its released, it might be fallen in paper bin.. You can see there is a cut at right side near blur lever,pull cutter bush up to there & load the cutter into cutter bush. Once hearing click sound manually confirm its fixed properly or not.. once its confirmed, push cutter in to park area, power on the printer..
Aug 01, 2012 | HP DesignJet 500 InkJet Printer
Replace hp designjet t1100ps hard disk
Designjet T1100ps -Q6687A.
08:11 error. The formatter is okay but the hard disk is bad. How can I load the system software in a blank hard disk or try to clone
Apr 28, 2012 | HP Designjet T1100ps Printer
Is not cutting and cutter is on, also, it is printing double lines
Fault: Double line & paper is not cutting.
>Check encoder strip, any damage or dirty?
>Clean encoder strip, replace it..
Reason why its not cutting?: Carriage moves to left side to lock & bring the cutter to cut the paper, but if its not reaching proper calculated destination due to dirty or damaged encoder, it wont lock the cutter to bring it out result paper wont cut even cutter in on condition..
Mar 04, 2011 | HP DesignJet 500 InkJet Printer
Designjet 2500cp error 010036 00000100
Hello. You probably have a worn out trailing cable. The manual says:
System Error: 010036 (see next page for 010036 0000XX00)
Problem Description: ADC Test Failure in the Main PCA.
Corrective Action: Try the following:
 Switch the Printer OFF from the back and
then disconnect the Trailing Cable from the
Electronics Module. Switch the Printer ON and
see if the Error Code now changes to “010037”.
If the error code remains as “010036”, replace
the Electronics Module �� page 8-6.
 If the Error Code changes to “010037” then try
the following:
Make sure that the Trailing Cable is
connected correctly.
Replace the Trailing Cable �� page 8-36.
Replace the Carriage Assembly �� page 8-42.
The manual can be downloaded at: www.lpscomputer.com/ec/manuals.htm
Apr 28, 2010 | HP DesignJet 2500cp InkJet Printer
HP Designjet 1050C Pluss - Error Code Question
Hi there only can try.
This is a firmware error, meaning your f/w simm is probably bad. You can try reseating the simm. It is behind the small panel in the back of the plotter, that is held on by 4 torq screws. Reseat all the simms that are present and see if that helps. If not, you probably need to purchase a new firmware simm.
Also try looking at
pulling the JetDirect card and then re booting it
Feb 10, 2010 | HP DesignJet 1050c InkJet Printer
HP Z6100 error code 01.2:10
01.2:10
Problem
Description:
ISS PCA problem.
�� Switch the Power OFF from the back of the Printer and disconnect the
Power cord. Reconnect the power cord and power On the Printer.
�� If the System Error continues, replace the Ink Supply Tubes and Trailing Cable.
Sep 25, 2009 | HP Designjet Z6100 InkJet Printer
What causes an error 24.10 on a designjet 4500ps
System Error: 24:10
Problem
Description:
Broken bag detected in Ink Cartridge.
�� Remove the Ink Cartridges and check for ink leakage in the ISS area.
�� Perform the "Bag Broken Recovery" Diagnostic (→ Page 4-51) to further
troubleshoot the error code.
Download the service manual at: www.lpscomputer.com/ec/manuals.htm
Jun 11, 2009 | HP Designjet 4500ps InkJet Printer
Computers & Internet Logo
166 people viewed this question
Top Designjet Black Computers & Internet Experts
David Payne
David Payne
Are you a Designjet Black Computer and Internet Expert? Answer questions, earn points and help others
