Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Brush bar does not turn & makes a loud noise
While using the dyson (pet model) it started to make a loud noise. I looked & discovered the brush bar was full of hair! I removed the bottom panel to get at the bar, removed the hair & it still makes that horrible noise when you engage the front to vaccuum. Upon inspection I noticed the bar did not turn when the machine was on. Help! I think I just broke my son's vacuum cleaner! I have a dyson dc07 and the brush bar rotates when its in the upright position and it keeps making a funny noise. I did take one side of brush bar out to clean it and not sure if i put it back in properly.
  • 2 more comments
  • clarerogers8 May 27, 2009
    Yes it is. wodered if the brush bar goes on a certain way but can only get the plate thingy on when its a certain way
  • Samuel Charles Spriggs May 11, 2010
    If the belt is on the long end of the steel beater bar axle, then it's installed correctly left to right.
    I would remove the beater bar again and clean/lubricate the bearings on each end. They should reinstall on each end of the axle and slip done into the housing -- this would allow you to get the cover back on.
    Does the belt have a flat spot on the inside where the beater bar axle has been rubbing it?
    Is the belt still installed on the brush (beater) bar?
  • Anonymous Mar 23, 2014
    Dyson pet hair tool stopped working. The two oval brushes seem to be locked. I can't see anything tangled in it. How can I fix it?
  • 58 Answers
You need to clean your roller and replace the clutch assembly that drives the belts. poorly designed vacuum with many flaws.
Posted on May 29, 2009
My dyson dc23 has recently started making a loud squealing noise. I have had it for about 3 years now with no problems. but it is so loud I do not even want to use it. I have checked it all over, no c
hi sophie, it's jack at dyson.
if your dc23 is making an unusual noise in use, this could be caused by something simple such as a part or seal being slightly out of position. the rotating brush bar in the turbine head floor tool is driven by the machine's own airflow, so if the brush bar won't rotate as fast as normal it sounds like something is also affecting performance.
this should be easy to resolve, and we may even be able to sort things out over the phone by talking you through some simple troubleshooting checks.
when you have your dc23 easily to hand, please give our experts a call directly on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
we'll look forward to speaking with you.
Jan 22, 2015 | Dyson Stowaway DC23 Bagless Canister...
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Noise
Hi there, it's Jack at Dyson.
I'm sorry to hear you're having difficulty with your Dyson vacuum. From your description, it sounds like the model number you've supplied may not be correct, as DC08 is a cylinder vacuum which doesn't use a belt-driven brush bar. So we can confirm exactly which model you own and take you through some quick diagnostic checks, I'd encourage you to contact us directly. You can reach our experts by calling 0800 298 0298 (UK), or 1-866-693-9766 (US).
We'll look forward to hearing from you.
Best wishes,
Jack - Dyson Official Online Customer Surpport
http://www.dyson.com
Apr 25, 2013 | Dyson DC08 Cylinder Bagless Canister...
DC07 grinding noise
I had the same problem with mine, I took it to a repair shop. The problem is where the belt passes through from the brush and goes inside the machine. Move the belt over a bit and you will see that a plastic guide has been bent over and is pressing onto the brush, which causes the noise. Just bend it straight again and it stops.
Apr 21, 2012 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson C07 ANIMAL is making a loud clatter noise when I push the head down. I have removed the sole plate and the brush bar is cracked so I removed it, but I understand the clutch maybe a problem also...
The noise is likely the clutch if you have a cracked brush bar. If so replace the brush bar, also replace the belts in the clutch or the clutch if the belts are stretched out.
Sep 12, 2017 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson Absolute has started making a loud noise and the has gotten progressively more difficult to push. I'm guessing the self-propel has stopped working. Is there a quick fix?
Hi its Darran at Dyson.
Try making sure the brush bar is turning when in the vacuuming position. It is possible that the brush bar is obstructed which can cause your machine to make this noise.
Check out our online help at www.dyson.co.uk/support.
Kind regards
Darran
Dyson Customer Service.
Apr 13, 2010 | Dyson DCO3 Absolute Bagless Upright...
Very loud click/catching noise - Dyson DC07Allergy
Take the sole plate off the brush bar (with a coin or a screw driver)compartment and check for blockages near the brush bar and make sure the brush bar spins round freely.
Its sounds like the clutch is slipping (it does this to protect it self from burning out when something is stopping the brush bar from turning)
A quick test is when in upright position turn the brush bar knob to off
(usally in drive postion) then try the user position again - the brush bar should not be turning and they should be no noise
Aug 23, 2009 | Dyson DC07 Allergy Blue/Turquoise Bagless...
When I tilt back handel and turn dial to carpet It makes a loud grinding noise
On a Dyson this engages the brush bar. Two possible faults: Debris (hair etc) caught in brush bar - cut out with knife. Or - damaged drive belt - pieces of belt striking casing. Last, but unlikely cause, debris in bearings of brush bar - replace brush bar.
Jul 29, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson Animal DC07 making a horrible noise!
Ensure plug is not in the socket.
remove the guard from around the roller on base of Dyson by turning 3 screws 90 Deg anti clock wise.
unclip belt from the metal spindle from the motor.
Pull out the roller.
Pull the end of the roller out.
They do not screw, they just pull out.
Clean the muck out from inside the roller ends.
Put end caps back on.
put belt on and thread through the slot.
put belt back on to motor spindle.
Ta da it stops squeeling.
Oct 16, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Hi.
You either need A new clutch or clutch belts need replacing.
Its a lot to describe so try this it has manuals on how to do the job.
http://dysonmanuals.inc.io/
Oct 14, 2007 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
916 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
