RUUD 13 SEER HEAT PUMP MALFUNCTION 2009 MODEL
My new outdoor unit(new ruud 13 seer heat pump) has a hammering noise at the TXV after cooling mode turns off, the noise lasts about a minute and is quite loud...also when in the heat mode the head pressure rises to 450psi in the first 30 seconds of operation in the heat mode, therefore i disconnected the ''blue'' reversing valve connection and only use it for cooling at this point but the hammering is most disturbing, my opinion is that the RUUD distributor sold me a defective unit with a faulty TXV/check valve.
Any help would be much appreciated!
  • ACSvcTechFL May 11, 2010
    you should still be under a parts and or labor warranty it really wouldn't hurt to call them
    Scholar:
  • 40 Answers
Unsure how long ago you purchased this unit, I can only respond to what I have read. I, as a homeowner, would not PAY a contractor until such contractor has properly INSTALLED and successfully TEST-OPERATED said unit/system in ALL MODES to the complete SATISFACTION of the homeowner. Then, and ONLY then, should a contractor be paid. If, in fact, the unit/system was TES-OPERATED in ALL MODES after INSTALLATION, and IF the sytem worked without that loud, hammering noise, then you need to contact the CONTRACTING INSTALLER and have them perform WARRANTY work, if it is sitll under warranty. Most manufacturers provide anywhere between a 5 year and 10 year warranty on their units. Good luck.
Posted on Sep 20, 2012
  • Ed Riggle Sr Sep 20, 2012
    By the way, I am a certified HVAC Technician and have worked in this industry since 1996.
Why is it that my Ruud central air conditioning unit blows out hot air only when it should blow cold air all the fans and compressor work inside and out. It worked for about 2-3 hr then nothing but hot air…
Posted on Jul 17, 2009
  • 614 Answers
I sell Rudd equipment. You have air in the system or faulty TXV. Replace TXV and evauate system. No more problem. Rusty
Posted on Jun 04, 2009
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
Ruud achiever series "10 seer"
You should see no ice. Turn it off for a while like and hour or so.. Do you feel air coming out of the vents?
Jun 26, 2011 | Heating & Cooling
My Weather King model # is 13PJA36AD1... supposed to be new...installed last July...I don't see it on your list though...Is it new?
The last order date for this product was August 2009. It was put on the market in 2005. It was marketed by Rheem/Ruud as a "Cube" heat pump. It is 13 seer efficiency.
May 18, 2010 | Heating & Cooling
Going to replace hvac system. Don't know what
According to the model number it is a 2 ton or 24,000 BTU unit. It is very important that you change the indoor coil as well as the outdoor section, due to it being a 10 SEER unit, and the new basic systems are 13 SEER, the old coil cannot handle the higher SEER ratings.
Rheem and Ruud are the same equipment, just 1 number different on the model number.
I hope this has helped, please rate the new guy :)
Please contact me if I can be of any further help to you.
Have a great day!
Sincerely,
Paul Gibson
Apr 04, 2010 | Ruud Matching Split Air Conditioner
Is there a system mismatch with an American Standard 13 seer 3 ton compressor and a Nordyne 3.5 ton air handler? Noise at TRV when heating.
This must be a heat pump? Sometimes the unit can be more efficient with this combonation. What you are probably hearing is the reverse direction of the
refrigerant going back through the liquid line.
If in cooling sometimes you can hear a gurgling sound going through the expansion valve, sometimes
this is a sign of low refrigerant or the system is fine..
If you recently had the outdoor unit replaced and noise is an issue, check to see if the unit has isolation pads installed underneath the unit whether
it be on concrete slab or on brackets mounted to
house. Sometimes the new units come with compressor that has a jacket installed over it
Feb 14, 2010 | Ruud Central System Air Conditioner
RUUD 14 seer heat pump makes loud squeeking noise after cycling.
Your problem is the TXV. I just had person with the same problem. Replace TXV no problem Rusty
May 01, 2009 | Ruud UAMB Air Conditioner
Model #uacc 030jas - BTU/H and SEER
that is a three ton unit and most likely a 10 seer rated seer rating are posted 6 months in cool and 6 months in heat to get the number on the unit if you are more interested in heating rating of heat pumps the aher or annual heating efficiency rating is of the most importance in this category the unit posted very well
Nov 14, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
453 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
