Unable to get the printer back online. I adjust in the setting module, it reads online. However when I return to Word to print, It gives the blue box reading Pinter offline again. please help
Elementary Solutions to Troubleshoot HP Printer Driver is unavailable in Windows 10:
There are thousands of printing issues and so are the solutions. There is no printing error without a solution along with that. So if your HP Printer becomes unresponsive after an upgrade, then here are the list solutions that you can try to erase the multifarious issues:
Solution 1: Fix HP Printer Driver Related Error
If the printer driver is not compatible with the system, you no longer be able to pass printing command. On such situation, you need to uninstall the printer and download the compatible printer driver again. Use in-built Add or Remove Programs option to make the process happen. Yet you can avail help from HP Printer Repair Service to avoid complicacy.
Solution 2: Fix HP Printer Software Related Problem after Upgrade
When you upgrade your HP Printer, you need to remove the software package present in the system. To do so,
§First you need to open Device Manager by typing it in the Start search box.
§When the Device Manager window opens up, click on View followed by choosing Show Hidden Devices.
§Make sure whether there are any entry related to HP Printer or not.
§If yes, remove the entries and disconnect the Printer.
§Restart the system to save the changes.
If You Still Get Stuck then Do Visit Us: hp printer driver unavailable windows 10
Toll-Free No: +1-888-633-7151
Check the status of the printer at Control Panel. Set it to online if it's shown as offline. If this doesn't fix the problem, check whether installing the vista driver available at your printer manufacturer's website helps.
Step 1:
a. Click Start, go to Control Panel and select Hardware and Sound.
b. Click Printer.
c. If the Printer is offline, it shows "Offline" status. If the Printer is online it shows "Ready".
d. If the Printer is offline, set it to online.
e. Right-click on the printer and select "Use Printer Online".
f. The display should change to ready when the printer is set to online.
Step 2:
If still you are facing issues, then update the printer driver. This should fix the problem.
For further precise instructions, please let me know the Operating Systems installed on the Computer.
Hope this helps..
Testimonial: "Im using a Gateway laptop and unable to find a simple online/offline button, dropdown or tab to select either status. Therefore, I still have the same problem!!"
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
