Question about Creda W120VW Front Load Washer
Easiest way to change drum bearings
Please could you tell me the easiest method of changing drum bearings on a Creda Excel 1200 V120VW
  • Anonymous Mar 15, 2014
    I need a bearing kit front back seal and drum seal for a whirlpool wwcr can anyone tell me what part numbers I need or where I can get one from please
I have changed the drum bearings on our Creda Excel 1200 V120VW. Not a simple job by any means.
The machine had to be just about totally stripped to get at the drum.
Before starting beware of sharp edges on just about any part of the machine
Remove all panels, top, rear, front facia, front panel including door, motor, powder draw
The secret is to remember to take photos or make drawings of the position of all the electrical wiring, hoses, covers and any other components you may be removing for access. Keep all you components together, it saves hunting for them later or worse still not refitting them.
Once the drum is out of the washer the drive pulley has to be removed. It is secured by means of a 30mm af nut which has also been fastened with thread locking fluid. Fortunately I have an electric ratchet gun, otherwise it would have required heat on the nut to defeat the locking fluid. The pulley is also threaded and was unscrewed with the aid of an application of WD40.
The front of the outer drum is unclipped and removed, the inner drum can then be removed by replacing the nut flush with the end of the thread, to prevent damage, and tappinng the drum out with a soft faced mallet.
This done you then have to remove the old bearings and seal. This is done be means of a drift and hammer, taking care not to bruise the area where the new bearings will be fitted.
The old seal may have to be destroyed by a sharp screwdiver or a proper seal removal tool.
When the bearings are out clean all areas with fine emery, lightly grease the bearing recesses and fit the new bearings and seal. Take care when refitting the stainless drum back into the outer drum not to turn the lip on the seal.
Now it's just a simple matter of re-assembly, make sure all parts remove are re-fitted in the correct sequence.
Another tip is not to put machine and all panels, ie; top cover and rear panels, back in place until the washer has been run and tested and inspected, to make sure there are no leaks and the machine goes through the cycles as it should.
Finally good luck!!!!
Posted on May 29, 2009
The stainless steel drum has broken away inside my creda excel 1200
This means that the drum support has collapsed due to corrosion.
It entails a complete strip down of washer, and replacing the drum shaft,and possibly new drum bearings and shaft seal also.
It is quite an involved repair, and not to be undertaken lightly.
If the washer is more than 5 years old, it would be more eonomical to replace it with a new washer.
Mar 22, 2011 | Washing Machines
Maytag Neptune Dryer MDE55000AZW As the drum is turning. there is a scraping noise . Not all the time, just as a certain point in the drum hist a certain point in the rotation. Help???
Sounds to me like your bearing and belt would be going out on the dryer you have to take the whole drum out to change this bearing set and belt not the easiest job to do.
Jan 17, 2011 | Maytag Dryers
Drumbearings - is it worth replacing them and
Spin bearing replacement is quite a big job..You may also have to replace the shaft which goes from the pulley to the inner drum.
The easiest way to do the job is to replace the rear drum, but the bearings and seals can be replaced individually...Get quotes for both methods..
Good luck....Nomess
Aug 03, 2010 | LG WM-1832C Front Load Washer
Creda tech came out, can he tell if machine belt is broke by just listening and turning the drum.
An experienced engineer would able to tell if belt is off, or if the main drum bearings were going, simply by spinning the drum by hand.
Feb 20, 2010 | Creda W100FW Front Load Washer
Creda 1200 Excel- The machine is not washing clothes properly and they come out as they went in. Nor does the dial move round on its own, i have to physically move it. At the end, there is still fabric...
this will help you with the fabric conditioner on Creda 1200
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 08, 2009 | Washing Machines
Manual for Creda Excel 1200 W120VW
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Thanks
Dec 15, 2008 | Creda W120VW Front Load Washer
Procedure for changing timing belt on single cam excel
okay easiest thing for you to do is go to autozone.com and look in the vehicle repair guide section this will give you good clear instructions good luck
Aug 23, 2008 | Hyundai Motor 1993 Excel
Creda excel 1200 front loading washing machine
This will either be a blocked pressure vessel, or the brushes on the Motor. I am not sure where the pressure vessl is on this model But you will find it buy taking the top of and finding a round or oval shaped component with a plastic tube running from it. carefully pull this tube of and blow down it. it should be clear. unplug machine first.
Nov 18, 2007 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
574 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
