Question about Kenmore Elite 45986 Front Load Washer
No power to machine - there is power to the plug
There is confirmed power to the plug. No power at the control panel. Is this definitive the Control Panel or some other problem? Machine will not power on, no lights, nothing. There is power to the outlet. Machine worked fine yesterday.
  • 1 more comment
  • Jason May 11, 2010
    You would need to check the power input at the control panel and see if you are getting the proper voltage at that point.
  • mochaman1973
    mochaman1973 Apr 06, 2014
    i agree. the board may have a short (check to see if there is a fuse there). i
  • mochaman1973
    of course, check to see if your power cord has a fray in it (these machines spin at high speed and sometimes, pending how they are installed, can shake something loose)
I had the same thing happen. I took the top off and realized that the power cord from the factory went out the back.....back in an opening.....across the back but on the inside and out another opening. The part crossing the back on the inside was near the motor and belt and was cut through the hot wire and ground. Someone has to be an idiot to run the wire in the design on the inside.
Posted on May 31, 2009
2 Suggested Answers
rickzilla
  • 706 Answers
SOURCE: No power to machine - there is power to the plug
I suggest that you unplug the power cord and gain access to the control panel and check all connectors to make sure they are properly connected to their appropriate mating connection. If they are Ok..then you may have a fuse blown. Hope this helps..
If you decide to diagnose the problem yourself, I suggest you unplug the washer before making your checks..
Good Luck
Posted on Oct 01, 2008
No power
What is the model number of your unit?
Jan 21, 2013 | Washing Machines
Bosch wfo2866gb wont work
Possible that the control panel had failed, there is a fuse within the control panel which needs to be checked. Most probably if this fuse has blown there is a short within the board which need to be confirmed for a board failure.
check this link to remove the panel: control panel
Jan 10, 2013 | Washing Machines
Flashing lights
Possible that the control panel has encountered an error and so is erratic.
Remove power for sometime and see if the machine resets.
If not the control panel board is a suspect. Remove the board to confirm the case , check the working of the power supply and processor.
Jul 05, 2012 | Washing Machines
Washing machine won't turn on!
Hi just read your posting.Now what happens to the machine when you unplug the machine from the power outlet then plug it back in and turn the power on to it?When your husband changed the display board or "control panel" did he reconnect the wiring harness to the main control module?Please reply with additional information on the questions and I am sure I can help you rectify this problem.
Jul 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Kenmore Washing Machine need repair.
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 04, 2010 | Kenmore Washing Machines
Kitchenaid Dish Waher KUDI01ILBS1 won't run from control panel
Sounds like the control is bad. Turn off the power, remove the two screws at the bottom that secure the kick panel. Remove the kick panel and look under the machine for a folder up tech sheet. This will tell you how to get the machine into diagnostic mode. Follow the instructions exactly and it will help confirm whether it is the control.
Jan 15, 2010 | KitchenAid Washing Machines
Whirlpool Duet will not work
Hi, you could have a control fault here or a door lock mechanism failure as well. the best way to find out if its ether the control or the door lock that may be faulty, is to unplug the unit for 5 minutes. this will drain all power from the control board, in return, resetting the program.
After the five minutes are up, simply switch your circuit breaker to the on position or plug the unit back in. If the control is working correctly, you should see a error code that says FdL(Failed door lock). If the control simply continues to malfunction like it was previously, this will confirm a major fault within the control board(microcomputer).
In this case, you will have to replace the control board in this unit. Remember, after the reset, power up the unit and watch the led and control panel carefully for any error codes. if the error code display is not functional, it will confirm control failure.
If you get an error code(FdL), check the wiring harness that connect the door lock mechanism to the control board. make sure they are in good condition and not lose. if the wires are ok, replace the door lock mech.
Please rate and god bless:)
May 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
Kenmore Elite 45986 Front Load Washer Logo
330 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
