Question about Ricoh Aficio 450 Copier
HOW TO FACTORY RESET THE SETTINGS OF AFFICIO 2035 E
HI I HAVE JUST PURCHASED A REFURBISHED AFICIO 2035 E, BUT I DO NOT KNOW HOW TO RESET THE MACHINE BACK TO ITS FACTORY/ DEFAULT SETTINGS.
ANY HELP WOULD BE GREAT
  • dean869 May 27, 2009
    thanks so much i will try my best to undertake your instructions, i am wanting to set the machine up on the network but the network cannot find machine, and this ultimately is what i want to fix
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; You have to print out SMC list before you clear all memory then to reset, the procedure as follow;
1, press "clear mode", "107".then hold down "clear/stop" key.
2 enter 5990 press enter.
3, touch on screen "execute".
after print out go backto clear memory.
4, enter 5801-1
5, follow the list to reset each item.
Posted on May 27, 2009
  • 162 Answers
Press . (point) and # Both simultaneously more than 10 sec this reset the software and reload the software default.
If there were some fault will print an error report.
Posted on Sep 22, 2009
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
May 19, 2010 | Ricoh Aficio 1018 Printer
Ok WHile I waited for the reset directions I took the fuser and roller assemblies off the 2035 I had and put them on this 2045. Still had the error. So I put them back on the 2035. Put the originals back...
Hello sir; I don't know what's the problem of the machine, anyway I can give you reset procedure; Press "clear/mode" "107" and press and hold "clear/stop" key for 3 sec.until screen change, then turn off the power and back on again.
Nov 13, 2009 | Ricoh Aficio 450 Copier
Parts and consumable of afficio 450
http://www.ricoh.com.ph/support/contact.html
Sep 07, 2009 | Ricoh Aficio 450 Copier
Ricoh Aficio 2035 all-in-one laser won't print from Bypass Tray
there are two places to set the paper tray on the ricoh aficio 2035 print drivers first make sure you are using the PCL 5 drivers not pcl6 or rpcs then go to the printers folder and set the defaults by right clicking the printer and selecting properties printing preferences, then go into word and select print set up and properties then defaults for printer select bypass tray and select labels enter the correct sheet size for the labels from the drop down box click apply and you should be set.
if this resolves your issue please rate my anser accordingly
regards
Aug 11, 2009 | Office Equipment & Supplies
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Fuser..?? afficio 450
The fuser probably will not help. I think you probably will need a PCU, and a service call.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
8,509 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
