At start up it says that mac address is invalid in both cmos and flash.
tried all flashers and mac changer but it is still the same.
The MAC address is burned in the Ethernet card chip, you won't see it in the Bios or if you do you can't change it. MAC address changer are tweaks to not being tracked.
The solution to know if the card is blown is to do a complete reinstall of your operating system and if then you can't connect whit it, it is indeed dead. Then Disable it in the Bios and had a PCI one to replace it.
Those kind of problem whit network cards happens a lot when you get a power outage, if you had one in the last couple of days your problem is most likely it.
Enter BIOS SETUP.
Can you change the MAC-address of the "built-in" Ethernet adapter? What's the current value?
Or, can you "disable" that "built-in" Ethernet adapter,
save the updated settings, reboot, and immediately power-off your computer, and then add a PCI Ethernet card?
