Question about Microsoft Xbox 360 Console
Connection of xbox360 to sony bravia kdf-e50a12u rear projection tv
When connecting xbox 360  to tv with hd lead there is ghosting.Tried 720 and 1080i on pal 60 checked leads were connected properly.I went through menu on xbox but could not solve problem please help!
  • 5 more comments
  • weedman2007 Nov 03, 2007
    mine does the same, i had xbox elite (2 of them) and now a pro consol, thought it was elite problem but the pro consol is the same!! its annoying
  • Anonymous Nov 04, 2007
    same here
  • Rhino5285 Nov 07, 2007
    also same here
  • Anonymous Nov 12, 2007
    yes just bought mine yestoday gutted tried taking it back . 30 day exempt on argos done the same put on 1080i it ghosting all the time but not on scart only hdmi this is a joke
  • maghouse Jan 11, 2009
    Snap - ghosting on the HDMI connection only .....
  • lfcforever Apr 11, 2009
    Same problem i had the men out twice to take the tv away to be repaired and it came back the same both times... Still ghost on the channel when i got the xbox on..
  • Christina Economou Dimitris Liarikos
    The above link is broken!
Http://www.avforums.com/forums/showthread.php?t=384717&page=8
3/4 down the page it tells you how to fix it
Posted on Nov 10, 2007
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
Ghost vision
wel if the ghost vision is still there try and set the brightness and contrast from your xbox 360 console
May 20, 2009 | Microsoft Premium System for Xbox 360
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
When connecting my HD cables I have sound but no picture.
this may sound silly but have you changed your settings on the xbox this is a common fault
Jan 05, 2009 | Microsoft Xbox 360 Console
XBOX 360 NO PICTURE
if using hd tv then use the cable with the blue lead, if not using hd tv then use the red, white and yellow leads. If using the scart connection to put the leads into make sure that you have it set to the correct av or ext channel
Dec 28, 2008 | Video Game Consoles & Games
I am Unable to connect my Aduio cables from the xbox 360 to my TV
1) Connect the red, white & yellow audio leads in to the 360 scart adapter and then plug this in to the scart socket on the tv
2) change the xbox 360 selector at the back of the console from HD to TV
2) Select the input of scart on the tv
You should now get pictures & sound.
Dec 28, 2008 | Televison & Video
Just bought xbox 360 to play on my hd ready 32"samsung tv,the console came up with message thatgames need to be played at 60 pal,so i changed it from 50 to 60 and now the picture(mostly the writing)is...
ive the oposit problem i want to play hitman which is 50hz game but im using a hdmi cable and it isnt possible to run it in 50hz , 60hz only i think so if you get the new hdmi cables it should fix your problem (if you have a hdmi port you should be using it anyway for the best picture)
Dec 14, 2008 | Microsoft Xbox 360 Console
Xbox 360 black and white
I would check to make sure your video settings aren't set to PAL-60 by mistake. It might be easier to resolve if you could let us know what leads you have and where you've plugged them in to.
Jul 24, 2008 | Microsoft Xbox 360 Console
Sony PFM-42V1N 42 in. EDTV-Ready Plasma
Yea the TV supports Pal 60
I had to use the bnc connection to AV. but yeah the tv supports Pal 60 you need to go into the menu and select it
just the colours arnt very good on this TV
Mar 04, 2007 | Sony PFM-42V1N 42 in. EDTV-Ready Plasma...
Microsoft Xbox 360 Console Logo
1,199 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
