Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP 6110 All-In-One Printer
The glass is dirty on the underneath side and I can't remove the glass to clean underneath. Can you tell me how to remove the glass so I can clean it? The manual tells you how to clean the top side but not the underneath side.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
There should be two screws on the right side of where the glass, take them out, some models you also have to take the screws off of the left side since it is one piece, lift the whole unit With the glass and set aside to clean. ( With power off)
Posted on Oct 23, 2007
Glass on copier seems fogged underneath\r\nsolution?
Paper dust? The scanning platen should be secured with a few torx screws. Remove, gently clean glass surface, and replace.
Sep 22, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Hp 6110 scanner making noise i can do any thing else because of that scanner light doesn't move, move little on scanner glass then come back on right hand side and keep making noise some time i can see...
If you cleaned the scanner glass before the problem began, it sounds like you messed up the homing strip underneath the glass. The scanner is trying and trying to find its home position and it can't. There is no way to disable the scanner to use the other functions. This is the downside to All-in-One machines. If one function (most commonly the scanner) stops working the entire machine won't work. I own a Cartridge World ink refilling store and I always caution people against buying all-in-one machines for this reason. It sounds like you'll need to buy a new printer, unless your printer is magically still under warranty you could call HP and ask what they can do for you. They'll probably just recommend you buy a new machine anyway.
Feb 24, 2010 | HP Photosmart C6180 All-In-One InkJet...
Scanner failieur and paper jam
This is a very common problem, and I have only found 1 really popular fix for this problem.
You must get access to the scanner bulb under the glass before the following steps can be taken.
There should be a very reflective mirror like strip underneath the bulb. This mirror like strip fogs up and gets dirty use after use. Take a cotton swab with a little alcohol and carefully wipe the mirror like strip clean.
This should fix the scanner failure problem.
If the problems persist, I would recommend getting a new printer.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 13, 2010 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 CLEAN GLASS ON SCANNER UNDER SIDE
Those models are difficult to open, they are all torx screws, all around the outside, screws in the front under the control panel, one screw under the narrow glass on the left. two screws at the back and another 2 on the right.
Dec 24, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do I remove the glass to clean both sides
u can read it here: threre are similiar problem resolved in fixya.com. good luck
http://www.fixya.com/support/t103792-scanner_failure_hp_6110_noise_stuck_head
Sep 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I have a officejet 6110 and when I turned it on the other day the scanner moves all the way to the right but never stops and sounds like a gear keeps slipping. Then a scanner failure appears on the screen...
Mr.Coiroj
This kind of problem creating from main dust only in Scanner Assambely so it must remove and make it clean; while you making clean use Soft Cloth to all the Glass to Clean; Do Not Apply Any thing in the Glass try it....
Jun 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 scanner glass is cloudy
Here is how, but it seems a lot of work.
- Remove all the torx-screws
- Remove the little glass on the left side
- Remove the Control Panel Cover (lifted it a little with a screwdriver and released two latches)
- Remove the Control Panel itself (another two latches&move to the left)
- The whole top of the 6110 is attached to the bottom with 4 latches. I remove that, turn it around and clean the glass.
Note: The cables between 6110-bottom and control panel/feeding unit are long enough to set those things aside.
Dec 06, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure hp 6110 - Noise and stuck head
Thanks to Silly Girl, I've got my HP6110 working again! Though to be honest, I almost gave up after trying out her suggestion by cleaning the glass and it did not work. I then removed the slider unit from the belt and realized that two of the mirrors were foggy. Again I cleaned them with a swab & windex, hooked them back up and... still the same problem. Luckily, I didn't give up. I took the whole thing apart again and this timecleaned the camera lens with a swab and it finally worked!!! So with Silly Girl's permission... if I may paraphrase her steps and add a couple to it in case people followed her steps and still did not work. 1. Disconnect the printer from all cables. 2. Remove all the screws that hold the glass panel (you do not need to remove the one screw that's on the left hand side, in the middle). 3. Remove the plastic panel that's over the buttons just by popping it up using a knife or something similar. 4. Extract the keyboard from the inside by unhooking the lock that's on the bottom right of the keyboard (close to the center)and slide the whole board to the left.
5. Then lift the upper unit with the glass panel and place it in the back standing up. 6. You can now reach the inside of the glass and clean it with a window cleaner using a dry clean cloth. 7. While you're at it, push that slider unit to the left and lift it out; the left side of the metal rod is not screwed in. 8. Remove the black slider unit by unhooking the belt from the slider unit and gently pull out the electrical harnest cable (you might want to mark one side with a permanent marker to remember which side when you re-attached the cable). 9. Gently and carefully pop open the cap on the bottom side. 10. Once it's opened, you'll see about 4 mirrors inside and a camera lens. Dip a couple of swabs in windex and GENTLY clean and dry all mirrors and camera lens. 11. Carefully re-install everything by retracing your steps. 12. Reset unit by pressing the # and the 6 keys together while plugging in the power. If you follow all the 12 steps, I guarantee the problem will be fixed and be just like new. Thanks again Silly Girl for the wonderful tip.
May 21, 2006 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
288 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
