Cannot add printer - Office Equipment & Supplies
  • 2 more comments
  • admin328 May 27, 2009
    I am using 3com Officenet Wireless 54Mbps 11g Access Point for my office wireless network. The i.p setting for the router is 169.254.83.1 At the moment, i'm trying to connect the router with a network printer (hp color laserjet 1515n). I had successfully install the printer driver thru the network. Unfortunately, i couldn't print anything thru the device. As temporary countermeasure, i try to replace the router with Prolink Wireless Router. The result is superb. I had no problem printing using that printer.
    To solve my problem, is there any setting that need to be changed on my 3com Officenet Wireless 54Mbps 11g Access Point, to enable me using the HP printer? For your information, the default i.p for the printer is 169.254.182.13 I did try to manually change the i.p address to 169.254.83.13 But, the printer didn't allow me to do so. ("invalid entry" message pop out)
    yes, i followed all the setup instruction. when i run the setup, it will automatically detect the printer that attached to the network and the installation runs smoothly. when the setup completed, i start with test print. you can see the message says 'printing'. but after a minute, the message says 'failed to print' not on that computer, but all other 30 computer that attached to the network. When i change to a Prolink router with same setting. it works! so, i think there must be some setting to be done in 3com officeConnect Wireless 54Mbps 11g Firewall router.Anyone had an experience configuring network printer this type of router?
    here some more info that might help. the 3com wireless router ip was set to 169.254.83.1 & HP color laserjet 1515n with automatic ip of 169.254.182.13 I already try to change the first 3 part of the printer ip to 169.254.83.XXX but the error msg 'invalid entry' come out. contact local HP but until now didnt call back for the solution. then i used a prolink wireless router with ip 192.168.1.1 Installation successful and i can print. so, there is no issue on the ip set. it just the setting on the router to be done. anyone firmiliar adding network printer to this 3com wireless router?
  • 6,487 Answers
The best way to fix this problem is to change the ip of your wireless router to a different IP like 182.168.2.1 and the printer will be 192.168.2.X.........
Posted on May 27, 2009
    President:
  • 1,383 Answers
First your wi fi printer seeems to not in network.
If there is any dhcp server restart it.
There must be issue with network printer ip addreses.
May be your router is dhcp server.
So check that the printer got ip perfacxtrly let me know sir.
  • 10,515 Answers
Are you sure that you have followed correct steps.Check the below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01514108&lc=en&dlc=en&cc=us&lang=en&rule=15018&product=3422468
Copy and paste it in browser.Create settings once again as per the link offered by Hp and let me know.
Thank for using Fixya.
Do rate the solution as "Fixya" if 100% satisfied.
    Sniper:
  • 73 Answers
Dear Client, here are the links that provides solution to your problems.
http://support.microsoft.com/kb/324757
http://msmvps.com/blogs/steveb/archive/2008/06/12/you-cannot-add-a-printer-and-you-receive-printer-spooler-error-messages.aspx
http://www.daniweb.com/forums/thread28527.html
Good Luck in correcting your problem.
Best Regards.
My canon mg5220 printer is not printing anything. It just says error when the pop screen pops up. It doesn't give me an error code.
Hi Savannah,
Try deleting the printer entry completely and add it from scratch.
Here's how:
  • Go to System Preferences
  • Print & Fax.
  • Select the printer you want to remove,
  • Click the - (minus) button at the bottom of the panel.
  • Reboot the system.
  • Run Software Update to check for the latest third-party printer software and updates.
  • Make sure the printer is powered on, has paper, and doesn't have any issues such as a paper jam or low ink.
  • Adding, managing, or removing print queues may require an administrator account name and password--make sure you know one for your Mac.
How to add a printer
To add a USB printer
Mac OS X v10.6 comes with software for many third-party printers, so simply connect a USB printer and the print queue will be automatically created. If you do not see your printer in the "Printer:" pop-up menu after connecting it, go to the "To add a printer via the Print & Fax preference pane" section below.
To add "Nearby Printers"
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on a Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
To add a Nearby Printer, all you have to do is select the Nearby printer you want from the "Printer:" pop-up menu:
Snow Leopard will automatically create the Print Queue.
To add a printer via the Print & Fax preferences pane
Control-click the System Preferences icon in your Dock and choose "Print & Fax" from the Dock menu. If the Print & Fax lock icon appears locked, click the lock icon and enter an administrator name and password when prompted. Click the + (plus) icon below the Printers pane on the left to open the Add Printer application.
From the Add Printer toolbar you have these default tools:
  1. Default - Used to get a list of all printers that your Mac can see via USB, Bonjour, and so forth. Tip: If you have a long list of printers, use the search field to find the printer you are looking for. Just click the printer in the list that you would like to add and Snow Leopard will add the printer driver for you.
    • Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. If you do not see your printer listed in the "Print Using:" pop-up menu or a Generic printer driver is selected, then the printing software may not be available from Apple. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
    • Once the driver is set, click the "Add" button to create your Print Queue.
  2. Fax - Used to add a queue for the Fax device connected to your Mac.
  3. IP - Used to add your printer network printers that don't use Bonjour or are on a different network subnet from your computer. Printers that support the Internet Printing Protocol (IPP), Line Printer Daemon (LPD), and HP Jetdirect (Socket) can be added in this manner. See your printer's manual or support documentation for information about how to setup the printer to use an IP-based printing protocol.
  4. Windows- Used to add your printer being shared via the Windows printer sharing protocol (CIFS). Tip: See Mac 101: File Sharing for details about how to add your Mac to a Windows Workgroup. This is often needed to see Windows printer shares.
Note: Any applications that are open before you add a printer will need to be quit and re-opened, in order to see all the features of the new printer.
Feb 19, 2014 | Canon Pixma Mg5220 Inkjet Multifunction...
How do I add a printer to the network?
How to create an IP address into your Printer
1, Connect to LAN network
2, Power ON the Printer.
3, Select MENU Button
4, Go to System Settings, then select Network Settings.
5, You can see TCP/IP , View IP ,etc.....
6, Type Your Printer IP address, Subnet Mask, GateWay, etc...
7, That's All......
In different Printer settings will be different.
Now You can add printer into your computer
Go to Control Panel--> Hardware and Sound -->Device and printers -->Add Printer-->Add network Printer-->"If no printer were found" Select "The printer that i want isn't listed" --> Add printer using TCP/IP--> Type your Printer IP address--> Now you can install printer software...
Thanks
Oct 10, 2012 | Canon imageCLASS MF4370dn...
Already installed driver from downloading online. cannot find driver printer in the devices and printer option of the control panel. cannot find driver when i started printing...
If you have not previously installed your printer or you did an uninstall before downloading the new driver, you now need to add the printer using the new driver.
In Windows 7, click on Devices and Printers.
At the top of the window you will see Add a device and Add a printer
Click on Add a printer.
Choose either Add a local printer or Add network, wireless or Bluetooth printer.
Follow through the choices and if the install program is not able to find the dowloaded driver, point to the location where your driver was downloaded. If you did not make note of the location you could run a search or download a second time making sure you save the driver to a location you can remember. You can then say Have Disk when asked and then browse to the location you saved the printer driver on your computer
If you have the correct driver for your printer and operating system the printer should complete installation
Dec 22, 2010 | HP PSC 1410 All-In-One InkJet Printer
My printer is turning on, but not printing, its telling me that the printer is offline and that there is a media jam. I have an I Mac please help.
Here's a quick summary of what's new for printing in Snow Leopard (read below for more details):
  • Apple's Software Update will automatically provide you with third-party printer software and updates.
  • "Nearby Printers" is a list of available printers that will appear right inside your printer dialog box. Adding a nearby printer is just a selection away.
  • You can simply connect a USB printer and the print queue will be automatically created.
  • You can create a PDF document from any application and have an automated workflow process it.
Before you connect your printer
  • If you are upgrading from Mac OS X v10.5, see "Upgrading Print Queues..." in the additional information section below.
With Mac OS X v10.6 you can quickly add a "Nearby Printer"--a nearby printer is a printer connected to the USB port on an Apple Time Capsule or AirPort base station, a network capable printer that supports Bonjour, or a printer being shared by another Mac. Snow Leopard uses Bonjour technology to find nearby printers.
nearby%20printer.jpg Snow Leopard will automatically create the Print Queue.
Note: Mac OS X v10.6 comes with software for many third-party printers. If an additional or updated printer software is available, Software Update will offer it to you. For more information about supported printers see this article. You can also visit the printer vendor's website for printer software, or contact them for technical support.
blank print _ fax system preference.png From the Add Printer toolbar you have these default tools:
Dec 11, 2010 | HP Hewlett Packard LaserJet P1005 Printer
Its identifying my printer as being offline, how do I correct it
Click on startà control panelàprinter and faxes.
Click on top left Add a printer option. This launches the Add Printer Wizard. Click next.
Select Local printer attached to this computer and uncheck automatic detect and install my plug an play printer option then click Next.
Now, Use the drop down arrow to select USB001 then click next.
Select the Manufacturer as HP from drop down list and select DeskJet 990c from printer drop down list. Click Next.
Verify the printer name and set the printer as default then click next.
Do not select print a test page option.
Click on Finish
Click on start then run type notepad.
Write any stuff and then try to print.
ADD A PRINTER IN VISTA
Click Start and click Control Panel.
Click Hardware and Sound then Printers.
Click Add a printer. This launches the Add Printer Wizard.
Click Add a local printer.
Now, Use the drop down arrow to select USB port 001 then click on Next.
Select replace current drivers
Click on Finish.
Click on start then search type notepad.
Jul 10, 2010 | HP Officejet 4315v All-In-One InkJet...
Please help to connect my kyocera mita km1530 printer to my pc. I could not add this printer to my pc.
Depending on what OS Operating System you have the instructions will vary. I will now give you the way to add your printer to Windows.
Before we start I will tell you if you're maxing out your resources it is very difficult to add a printer without taking another off.
That said. -
1- remove all other printers if there are any
2- if there is any software with the new printer put the disk in and run that program. -
3- if you do not have a disk with your unit and your getting the message there is no driver - google the brand and model of printer and add the word driver - then select to find the driver on the suggested website and down load to your desktop. If you never did this - write down the name of the file you are downloading then SEARCH for the file name you write down.
4 open the file and run that program to add the driver to your pc.
5 - plug in the printer and turn it on.
6- click on START -look for settings - then click ADD PRINTER or PRINTERS - open this and click add printer.
Number 6 will vary depending on how you have you pc set up to show your programs and things - so if you can't seem to make that work just search ADD PRINTER and that should do it - if not - go to HELP and then search add printer.
If you have some follow up questions just come back here or email me at riceski@gmail.com
Also there are tutorials on YOU TUBE that might help you - just go to YOU TUBE and search ADD PRINTER www.youtube.com
I hope this helps you get your printer added
please rate me - - thanks
G
Mar 18, 2010 | Computers & Internet
How to install destop printer in ubantu
1. Just hook up your printer to your linux machine and reboot your system
2. your system will automatically detect and installs your printer.
3. If not, then goto control panel .. find printers settings from there and manually add the printer. You may have to select your exact printer model while adding your printer manually to the linux machine.
I hope this is helpful to you.
Thanks
Mar 14, 2010 | Epson Stylus C86 InkJet Printer
I need to install my new HP Officejet 6310 and set it as the default printer . I don't have a Installation CD Rom
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER WITHOUT CD-Rom
STEP 1: In your computer window click the Start button and select the option Devices and Printers.
STEP 2: A new menu Devices and Printers appear on the screen. Then click the option Add a printer.
STEP 3: After clicking the Add a Printer option two options appears on the screen.
Add a local printer
Add a network & wireless or Bluetooth printer.
Select the option that suits to your printer
STEP 4: If your printer is not a wireless then select the Add a local printer and select the option Use an existing port then click next.
STEP 5: Scroll down to select the HP in the manufacturer section.
STEP 6: Select your Hp printer model in the printer section then click next.
STEP 7: If your model number is not present then click the windows update it will automatically add your printer model.
Note: You must need internet connection to update the printer model to your computer.
STEP 8: Then click next and finish.
STEPS FOR INSTALLING THE HP OFFICEJET 6310 PRINTER FOR WIRELESS CONNECTION:
Add a local printer
STEP 4: Select the option Add a network, wireless or Bluetooth printer and click your printer name and address.
STEP 5: After the HP officejet 6310 printer installation of your wireless printer next step is to add your printer name and click next.
STEP 6: Set default printer as your HP Officejet 6310 printer and select the option print a test page.
STEP 7: A new popup window appears on the screen, then close it and finish.
Jun 11, 2009 | HP Officejet 6310 All-In-One InkJet...
Need to add a printer
If ur using Windows XP:
go to control panel, add hardware, add printer
If ur using Windows Vista:
go to control panel, click Hardware and Sound, Add Printer
hope this could help :)
Aug 28, 2008 | Office Equipment & Supplies
USB to Ethernet adapter for printer
to run your printer on the network follow this steps. ist add your printer in your 1PC then share it. then add printer to your pc3, pc4.
To do this go to Start Menu/printer and faxes/add printer/follow add printer website. Do this process again to PC2, PC3
Mar 16, 2008 | Computers & Internet
193 people viewed this question
jasbo
jasbo
