My pocket pc requires screen alignment, i have been tapping the target many times but it does not get aligned.
Hi. You should tap the screen with the stylus carefully and with a little bit more pressure, accurately on the cross sign evertime it appears. When you successfully tap each cross sign once, you would be able to pass to the other settings, but in case there is a problem passing though the screen aligning, here is a small tutorial about how to bypass that screen through your PC: (http://goatechno.blogspot.com/2008/12/windows-mobile-stuck-at-screen.html) Hope this helps.
Tap the screen at target for some moment of time again & again until align screen don't go. After disappearing this time & date setting option will come.set these.after that windows installation will be started.It takes few minute.during installation don't press any key.after this phone will be started.
