Question about Samsung SyncMaster 2233BW 22" LCD Monitor
Can't get monitor to connect
Samsung 2233 problem: I've attached the digital lead properly and turned on the monitor and pc. All I get at first is a little box in the top left corner which changes between reading 'analog' and 'digital' - nothing seems to affect this box. Eventually it goes a way and is replaced by a white box moving round the screen which says: "check analog signal" I've tried connecting the analog lead as well but it doesn't make any difference. Any ideas?? Thanks so much.
  • mongoosier May 27, 2009
    Sorry 2233SW if that makes a difference!
    Scholar:
  • 84 Answers
There are a few things to look at. It is very obvious that the screen is in good condition since you can see the message on it. Now the problem lies with either the RAM and/or the VGA. If you are using an onboard VGA, try a PCI VGA card. Try to resit the RAM modules also. If you have more than one mem chip, then do it one after another. It might be one them is fault and hence blocks the signal to video. Finally, any newly installed card should be temporarily removed ok. With these, I am sure the problem will be over. Good luck
Posted on May 27, 2009
Pictures are squat. Toshiba Tecra A9 and just connected it to my Samsung SyncMaster P2070 20 inch LCD Monito. I've used the Samsung tool to install the correct driver. But I cannot get the display to...
if you stillhave problems with yur new monitor the problem could be in the computer itself
test all leads that attach to your hard drive including electrical extensions,IDE,SATA whether on a desktop or laptop
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
click start control panel,display,desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
Oct 11, 2011 | Samsung SyncMaster P2070 20 inch LCD...
My SyncMaster 2233 has problem, it has two straight lines, one blue, one pink, across the screen, from top to the bottom. I'd like to know how to get rid of it.
If the lines are very thin, they are broken pixels. You have to replace the monitor. I've heard of people taking their finger and trying to rub the lines out, but I have never had success with this before.
Sep 13, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
How do I clean my monitor screen Samsung SyncMaster 2233?
There are solutions available that you can use to clean your monitor.
What I do is using a clean cotton cloth I dip it into small amount of water and wipe the monitor screen with it.
Hope this helps!
Sep 10, 2011 | Samsung Computers & Internet
How to connect television cable and samsung sync 2233
Samsung SyncMaster 2233BW does not support TV / Cable input (RF Connector).
If you wish to connect Cable to the LCD, you have to buy a TV Box and connect Cable with your LCD through TV Box. (Cable TV to TV BOX and from TV BOX to LCD)
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 09, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
My problem is when I turn off only the monitor then turn it on again it turns the display black and no image that you see. the only solution I know is to force my PC to turn off then when I Turn on my PC...
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
May 07, 2011 | Computers & Internet
I have two monitors. One Samsung SyncMaster 2233 an one Samsung SyncMaster 2243. My problem is that the SyncMaster 2233 for some reason is totally black. I'm usually not terrible with these things, but my...
You're using dual monitors and one is black? If so-- when you switch the cables on the monitors.. the same monitor stays black? This sounds like bad monitor. If I understand you right.
Feb 10, 2011 | Computers & Internet
hello Gabriel
Could you check your SyncMaster 2233 for me and tell me your findings. If this monitor is connected from your computer and when both switch on, did the led indication lamp from your monitor lit steady green? or this lead indication lamp lit green then turns red?
1. If the led indication lamp lit steady green then there is nothing wrong with the settings, configurations, driver or hardware on your computer. The problem would be the backlight inverter lamp in your monitor is busted. Or it could be the inverter board that supplies high voltage for the backlight inverter lamp that is bad. You can replace the backlight inverter lamp located at the upper and lower part of the monitor with a replacement part you can purchase at shoppejimmy.com. Inverter board repair can be risky if you don't have the skill. Even opening the back cover of your monitor and replace by yourself the inverter lamp is risky too, could inflict more damage. you can bring it to a local professional service man.
2. If the led indication lamp lit green then turns red, then if not the video card the power supply section from your monitor is bad, you can replace polarized capacitor with same value. Just inspect and those with blown or leaking capacitor. You can also check the terminals and solder joints for the 15-pin vga terminal connector where vga cable is connected on your monitor. Resolder the terminals.
3. If the red indication lamp did not lit at all. Power supply section in the monitor is bad. You can check the output voltage from the power supply section. +5VDC is supplied for the main board and +24VDC is for the inverter board. Replace leaking or blown capacitor with same value.
Just remember, this should be done when computer and monitor is turn off
Post back if you have more questions. I am willing to give you assistance.
Feb 10, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
The picture frequently breaks down into blocks of colour. my monitor is connected to the digital output on my pc and it is 8 months old
The first thing to checkis that the plugs on each end of the monitor lead are firmly attached. Next check that your graphics card is firmly seated in its slot. Next try a new DVI cable. If none of these work you may have a broken monitor.
Oct 31, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 2233 stuck in analog
in your mon there will be small left arror image in box called enter button,,,,if u press that button its shows analog and digital in that have to choose digital.....
Apr 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 2233BW 22" LCD Monitor Logo
340 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
