Question about Nikon Speedlight SB-600 TTL Flash
Sb-600 battery leakage!
Hi, im new here. thx in advance for ur help.
last week i misplace a leaking battery to Sb-600.
After that the flash cannot be turn on anymore.
Bring to service center the technician claim there is battery leakage.
Cost almost 1/2 of new flash to repair it.
Any 1 can help whether can DIY repairing it?
5 Suggested Answers
  • 8 Answers
SOURCE: flash is not working for a nikon sb-600 speedlight
zoom the flash all the way in so you can see if the flash bulb is broke
Posted on Mar 20, 2009
SOURCE: Using SB 800 flash Master with 2 SB 600 as slave
Hi Frank, I use the same combination of the exact three flashguns you have. Works beautifully. I mount the sb-800 on my camera and set it to Master Mode (press and hold the center button till the menu comes up, select the master). Set the other two sb600s as slave. Please make sure the channel is set the same in all three flashes... when positioning the slave flashes, make sure that sensors on the remote will recieve the light from the main flash. For maximum coverage I use the sb-800 with a diffuser in bounce mode. You will be amazed at the quality of interior phots you can get with a 3 flash combo.
Posted on Apr 23, 2009
  • 14 Answers
SOURCE: Nikon Speedlight SB-600 keeps firing
I believe that there is a safety feature built in that if the voltage in the capacitor gets too large the flash will fire, to prevent damage, could be this that is faulty, if it is a new main circuit board is required.
Posted on Sep 04, 2009
  • 411 Answers
SOURCE: my nikon SB-600 doesn't flash at all ?
discharging section of the flash is defective,replace the xenor tube,see that will be flashing.
Posted on Mar 29, 2010
Testimonial: "Quick response and precise answer..."
Corroaded contacts on my nikon sb600
If its not that bad , use a pencil with eraser better yet an ink eraser and rub the contacts
Nov 15, 2013 | Nikon Speedlight SB-600 TTL Flash
Bought a Nikon Speedlight SB-600 in August. Tested the flash and it fired ok. I took out the flash a few days ago to use at a graduation and the "ready" light did not come on. Consequently it did...
Hi grwcamp, Sorry to hear about it not working at the graduation. Are in the correct position (I am sure you did but, we must start someplace). Look inside, see if there is battery acid in there.
If with new/fresh batteries it still does not work call Nikon. You have a warranty on it so it should be covered.
Nikon digital 1-800-645-6689
Dec 04, 2010 | Nikon Speedlight SB-600 TTL Flash
SB-600 flash suddenly dead. Found some early corrosion on the AA batteries. What happened? Repairable?
Hi degossman, Corrosion is sometimes a fix us users can do. Other times it must go in for repair. What happens is the corrosion may leak past the point we can see in to the internals of the housing eating out wiring.
Nov 30, 2010 | Nikon Speedlight SB-600 TTL Flash
I have a Nikon Speedlight SB-600 that needs repair. The flash does not operate. I believe there is no connection made with batteries.
Check the battery contact make sure they are clean. If a battery leaked, even a little battery fluid on the contact then that could be the problem.
Nov 11, 2009 | Nikon Speedlight SB-600 TTL Flash
SB 600 has stopped firing batteries are good
flash bulb could be burnt out...if it doesn't fire when when you push test, that's my guess as to the problem. Another possibility (although unlikely) is a loose connection in the flash.
Oct 23, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Problem with SB-600!!!!
    Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
    Sep 18, 2007 | Nikon Speedlight SB-600 TTL Flash
    My Nikon SB-600 speedlight seems to have died - only had it 2 years. Could it be because of battery leakage - I found some suspicious looking wet-stuff inside the case. Batteries haven't been there that...
    You may be lucky because the battery acid may not have gone beyond the contacts in the battery chamber: open battery chamber and clean out especially at the bottom of the chamber and blow out any loose stuff when you finished cleaning ( use pencil erazor or something similar , but do not use sand paper or anything that will damage chrome plating of the contacts ; you do not want corrosion at later stage ).
    Feb 20, 2007 | Nikon Speedlight SB-600 TTL Flash
    Nikon Speedlight SB-600 TTL Flash Logo
    308 people viewed this question
    Top Nikon Cameras Experts
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
