Question about Canon PowerShot SD1100 IS Digital Camera
When I turn my camera on, it will than read: "lens error, restart camera."
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on May 27, 2009
Thanks Mate, I have a canon ixus 6 that brought up this error and wouldnt extend the lens .. after trying all the suggestions in correct order it still wouldnt work. Well being told by a repairer that it wasnt worrth a fix, I decided to pull it apart myself for a look. (note) I have no knowledge of cameras at all.figuring it was the motor drive for lens opening that was in question i removed this from the lens a quite simple but fidly job, I then operated the gear by hand and drove the lens in and out ,decided to test motor to see if it worked by putting battery back in and turning cam on .. found it didnt work tested for volts at motor and found nothing .. connected a 1.5 volt battery to motor and it drove at this stage the lens was still extended so decided to shut it by hand and try again .. this time the motor drove correctly ,I reinstalled motor to lens drive and it has worked perfectly ever since .. a few things to take note of though . make notes or take pics with another brand camera ..lol of the disassemby I had a few screws left over and a thin metal plate that dropped out from god knows where ! nevertheless the cam is working fine still ..ohh and beware of the charged capacitor for the flash ... ouch !!it packs quite a punch ...just goes to show anyone can have a go at basic fixes that so called repair shops deem to expensive .. Paul ... Aus
Posted on Jun 03, 2009
When turning on the camera it shows 'Lens error restart camera'
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Aug 10, 2009 | Canon PowerShot A470 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
Canon camera when turned on, lens will not
Hi
What you are seeing is a generic error message, starting your camera again won't do anything unfortunately.
You need to replace the lens, we have your lens repair available on our site for about $75! If we can help please let us know.
Thomas
Owner- Darntoothysam com
Apr 04, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Canon powersho SD750, restart camera
Hi
Your lens is defective needs to be cleaned, repaired or replaced if you are seeing an error message that reads "E:18" or "Lens error, restart camera" or something similar. Turning the camera off and back on again will not fix the problem unfortunately.
There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know this because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help! Good luck from
Darntoothysam com
Thomas
Oct 04, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Lens Error, Restart
Nikon System error help????
Sep 05, 2008 | Nikon COOLPIX L12 Digital Camera
Cannon ixus 65 digital camera
When I turn on the camera , the words lens error, restart camera apaers on the screen.
The camera then turns it self off.
Jul 10, 2008 | Cameras
Lens error
sir,problum is ur lens unit,some mechanical or dislocations,gears this is repairable u try ur local service center
Apr 11, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon SD900
First off, see if Canon can help you. If not, the following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 28, 2007 | Canon Digital SD900 / IXUS 900 Ti Digital...
Canon PowerShot SD1100 IS Digital Camera Logo
344 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
