My R120 DVD Recorder has suddenly stopped me from either FORMATING, INITIALIZING or DELETING MY DISCS I am usind DVD-RW Sony
  • perlcole May 27, 2009
    Thankyou for reply but I have to say that I have been using this make of disc for some time very succsesfully.
  • perlcole May 30, 2009
    It confirmed my own thoughts thanks tho'I was hoping the answer would be different as the DVD Recorder is not an old model.
    Thanks all the same
  • 10,515 Answers
All DVD recorders have certain brands of disk that they like, and other brands that they don't. Sounds like your DVD-RW is a brand that your DVD recorder does not like. If your PC does not recognise it either, it might just be a dodgy disc. Try another of the same brand, but this time try it in your PC first. If that one isn't recognised either, avoid the brand in future.
Any further help, let me know.
Thanks for using Fixya.
Do rate the solution as 'Fixya' if 100% satisfied.
Posted on May 27, 2009
  • taran_2005
    taran_2005 May 27, 2009
    In this case, as you are sure that this Sony disc is compatible with your Samsung R120, its time to change recorder.
    I know it's frustrating, but that would be the precise solution as i am sure that the unit has been damaged. There is no point of repair as it would cost less than 50 bucks to purchase a new one.Even if you use different format of Cd's, still it would show the same concern.The hardware issue is more costly as compared to repairing the same.
    Rest on you. I am sure you would take a wise decision.
    Do rate the solution as "Fixya" if 100% satisfied.
How do you delete videos from your sony handycam DCR-DVD405
This Sony camcorder uses mini-DVDs to record and there are certain restrictions when DVD is used, it is not like videotape. For a DVD-R disc, you cannot delete video once it is recorded because this type of disc is a record once only. Depending on which other disc type you use and how it was initialized, you MAY be able to delete video. For a DVD+RW disc, or a DVD-RW disc initialized in VIDEO mode, you can delete the last scene IF you have not removed the disc and not recorded any new video. For a DVD-RW disc initialized in VR mode, you can delete anytime. And here is how:
Turn on camcorder and press PLAY. Select the video or still image tab that contains the data you want to delete. Touch EDIT. Touch DELETE. Select what you want deleted. The selected scene is marked with a checkmark. Press and hold the image on the LCD screen to confirm. Touch RETURN to go back to previous screen. Touch OK - YES. You cannot recover data once deleted. There is also a DELETE ALL to delete all video or images.
Mar 22, 2011 | Sony Handycam DCR-DVD405 Camcorder
The dvd wont initialize blanc discs so that i can record with it.i have used different disc as well
Do you mean it won't format/initialize the disc? Alternative possible problem, when you put in a disc, does it not recognize that a blank disc is in the unit? Only DVD-RAM discs need formatting. DVD-RW discs need to be initialized. DVD-R disc do not need either formatting or initializing. (This unit does not write to DVD+R or DVD+RW discs.)
In the case of DVD-RW discs that can't be initialized. Check if this has already been done (or if you need to unfinalize the disc).
If the new disc is not being recognized as a blank disc, the recorder may not be recognizing the disc (dirt, scratches or manufacturing issue) or the recorder is not focusing on the disc properly. In the first case, clean the disc or try a different type of disc (Samsung claims that their discs will be most compatible). In the second case, the unit may need service.
I hope this helps.
(usually tracking and focus problems will be seen on both recording and playback (even with commercial discs).)
Oct 30, 2010 | Samsung DVD-R155
I get a message on the screen that says, "recording disabled." How do I fix this? I have a Sony Handycam DVD/RW Wide LCD
This message appears when mini dvd disc got some error in recording tracks, if its rewritable mini disc then format it as option is available in camera settings menu and if disc is once writable then use another disc as it can not be formatted.
Caution: Format will erase/ delete all files on dvd disc and refresh the dvd disc.
Jul 25, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
Erasing the disc
it would actually depend on the type of disc your using for you to be able to erase the contents of the disc and reuse that same disc for new recordings. it's called "formatting the disc". it deletes all recordings and returns the recording medium to its original empty state. this operation is possible if you are using dvd-rw or dvd+rw (re-writeable) discs only. please refer to pp.12-13 of your camcorder's instruction manual for more information about disc format features. hope this helps. thanks:)
May 28, 2010 | Sony DCR-DVD608E DVD Camcorder
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Sony dvd rdr gx300 failure to delete discs
You can delete titles on a DVD+/-R, but it will not free up disc space. These are not "rewritable (RW)" disks.
To reuse discs, start with a DVD +/-RW. Be sure to format it "VR," not "Video."
http://esupport.sony.com/perl/model-documents.pl?mdl=RDRGX300
Oct 12, 2008 | Sony RDR-GX300 DVD Recorder
Format a cd
First some explanations:
The Canon DC210 will only take 'minus' format DVDs (DVD-R, DVD-R DL and DVD-RW). Only the DVD-RW must be formatted (initialised) before use. During initialisation you'' be asked whether you want to initialise the disc in VIDO mode or in VR mode.
VIDEO mode: Once finalised discs recorded in VIDEO mode can be played back in most common DVD players, offering the best compatibility. However, recordings cannot be edited (deleted, rearranged etc) on the camcorder.
VR mode: You can easily edit the recordings on the camcorder. However, discs recorded in VR mode can only be played back with DVD players that are compatible with DVD-RW discs in VR mode.
My preference is Video mode - I can then play the disc on a DVD player and edit it on a PC.
Now, to initialise a DVD-RW
1. Press the 'FUNC.' key
2. Use the joystick to select 'MENU' - it's in the bottom left corner of the screen
3. Use the joystick to select 'DISC OPERATIONS'
4. Use the joystick to select 'DISC INITIALIZE'
5. Use the joystick to select either 'VIDEO' or 'VR' mode
6. Use the joystick to select 'YES' to confirm your choice
7. Use the joystick to select 'YES' to start initialising the disc
Close the menu only after the screen display returns to the 'DISC OPERATIONS' menu.
Don't forget to rate this solution once you've tried it !
May 11, 2008 | Canon DC210 DVD Camcorder
Cannot initialize DVD discs. Same one I always used Sony rw. Seemed to work fine for ages now doesn't want to initialize any of them.
are you using + or - discs and are they the same type of disc which your programme was originally recorded, as a minus pre recording will not be able to be written to a plus disc so make sure both formats are same
Apr 13, 2008 | Televison & Video
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Loading DVD-RW discs
My recorder has stopped accepting NEW DVD-RW discs and ejects them.
There is no problem loading DVD-R (new or recorded)or loading previous recorded DVD-RW, initializing and re-recording
I have tried several different DVD-RW makes. Puzzling??
Nov 03, 2006 | Pioneer DVR-5100H DVD Recorder
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
