Question about KitchenAid K45SS Classic Stand Mixer
Kitcchen Aid mixer making a grinding noise
Hi - I have the Kitchen Aid Ultra Power 300 stand mixer.  While making batter for banana bread this morning it started making an awful grinding sound.  The mixer still turned, but the noise is unbearable and the unit started to get very hot. I've had it for 12 years now and use it only once or twice a month, cleaning it and putting it away after each use.  Any thoughts?
Thank you!
  • rustle Nov 22, 2007
    my mixer started having a low level grinding noise as if something was loose and then stopped turning on all together. Is there a manual to describe disassembly of the mixer?
  • 45 Answers
Common problem. Worm gear & bracket #PS734273 about $36.
Posted on Nov 05, 2007
  • Russ
    Russ Jul 07, 2016
    Changed our worm gear, cleaned and installed new grease and still has grinding scratchy sound when mixing dough
    Top Expert:
  • KitchenAid Master
  • 18,363 Answers
Need to check the worm gear and bearing one of either is in need of repair
Posted on Jul 07, 2016
How to use food grinder attachment
The mixer's planetary is not disconnected when the meat grinder is attached and continues to turn.
If the noise you hear only occurs when the grinder is in place, then the grinder may be assumed to be the cause. Consult the meat grinder's instructions and make sure that nothing is loose or overtightened.
Mar 04, 2015 | KitchenAid Kitchen Aid K45SSWH Classic...
My Kitchen aid Ksm90 mixer got a little noisy, then it just wouldn't even turn on. What could be wrong with it?
You have possibly blown the fuse gear. Need a bit more info on the noise. If you turn it on slow and help the planetary does it try go get itself going?
Jan 16, 2015 | KitchenAid Kitchen Aid Ultra Power Tilt...
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
Oct 17, 2014 | KitchenAid Kitchen Aid KSM150 Artisan 5...
Kitchen aid stand mixer ultra pro 300 will not turn on
Sorry but we really need more info. what happened last time you used the mixer? have you pwerformed any work on the machine? have you checked the wall outlet you plug the machine into ( Iknow but check anyway)
Jan 05, 2013 | KitchenAid Food Mixers
No power to my kitchen aid mixer
please i need help kitchen aid mixer i have no power
Jun 27, 2012 | KitchenAid KSM90 Ultra Power Series Stand...
I have a 275W Classic Plus, about 5 years old. I've never done any maintenance on it. It gets used several times per week for the basics (banana bread/cake batter, cookie dough) and also at least once a...
There are lots of places to be looking, first thing I would look at would be under the rear cover to make sure the two nuts that hold the rear motor bearing housing in place are nipped up. You don't wring the neck on these nuts, if you over tighten them you will deform the rear bearing housing.
If you can find someone local who has been doing these mixers for a while they will be able to give it a once over. It's unlikely to be expensive. Best people to ask is Kitchen Aid, they should know who does their warranty work in your area. If you are in new Zealand it will be me.
Jun 30, 2017 | KitchenAid K45SS Classic Stand Mixer
Grinding noise when running.
It very likely sounds like a plastic gear that is worn. If this is the case, then a replacement is very likely stocked by the manufacturer only.
I advise opening the unit to identify which one you need, then 'phone the manufacturer with the make model and year of the product.
If they say they do not stock it - then I'm afraid that's as far as you can go with this.
Aug 16, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Is 300 w mixer powerful enough to mix bread dough?
Your mixer is easily able to handle the kneading of bread dough. Please advise:
9 cups of all purpose white flour, maximum.
6 cups of specialty flour, maximum. This is any flour besides all purpose white.
Bread doughs are only to be needed on speed 2, and never for longer than 7 minutes.
This is all stated in the Use and Care guide for the mixer itself. If these guidelines are not followed, it may lead to a product failure.
Jul 02, 2009 | KitchenAid KSM90 Ultra Power Series Stand...
Grinding Noise
If it's metallic sound you are loosing teeth on a gear or two.  This is caused by lack of lubricant or simply fatigue of the material of the gears.  Don't use it, you can get metal flakes in your food.
Take it in to a repair shop and have it fixed.  The money spent is well worth it because if done correctly will last another 12 years.
Oct 21, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
KitchenAid K45SS Classic Stand Mixer Logo
1,794 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
