Question about Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive
Maxtor Mini 9NX2DC-500 not working
My Maxtor Mini HD was working fine after purchase, connection, formatting and loading with files. Accessibility OK too.
Then after a few months I noticed it was beeping three times when I boot up the computer. Still working though. Then I defragged my main HDD and decided to defrag the Mini while I was at it.
At completion of defrag a box came up telling me that some files were corrupt or deleted but when I looked I couldn't access any files on the drive. It appeared to be empty. Left as is for another time to investigate, but then one day when booting up, the Mini was beeping continuously and couldn't be accessed at all. My computer was also booting to the desktop stage and then restarting itself. Disconnected the Maxtor Mini and solved that problem. Why did defragging stuff up the working Maxtor and what can I do now to get it going? I just want to get it running so that I can reformat it and start again. I don't remember that it came with a software disk and I looked in my carefully preserved pack of software disks and don't have one, so I'm confident that I never had one. I was also running it from a 4 port hub, one (data) plug there, and the other (power) plug to a USB port on the back of the computer case. Still under warranty but I don't want to return it due to personal material (nothing illegal, just personal) on it. Thanks heaps for any advice guys and gals!
I have a Maxtor onetouch 4. I want to use it as an external hard drive. Windows explorer recognizes it but when I try to copy files to it, it says the drive is write protected. I down loaded the Maxtor...
That's because the software it comes with unlocks the drive to do backups. You should be able to format the drive in windows and then it should work fine for your purposes.
Right Click the Drive, Select Format, give it a volume name if you want and select quick format. Leave everything else default.
Comment back if you have any questions
Sep 11, 2011 | Maxtor OneTouch III Mini Edition 120GB...
Hello! my device is a maxtor portable storage device PN:9NX2A4-500 SN:2HB18R9R. It has been self-formated somehow and is not traceable by any laptop or desktop I have tried. Is there any kind of free...
If it just been formatted and still works and in case you didn't wrote on it anything since the format,the only thing you can do it try to recover the files from the drive, you probably can forget about the OS. There are 2 good apps out there:
  • Recuva - A freeware app, does the job fairly.
  • File Scavenger - For 50$, if you really need those files.
Good luck...
Feb 13, 2011 | Maxtor Hard Drive
Hi there i hav ea maxtor onetouch 4 mini 120 gb.
Remove the hard drive from the Maxtor case, purchase an USB hard drive adapter case, and install the hard drive inside this case. Then you can connect this to the computer's USB port and if the hard drive is OK then this computer will detect it as an external USB hard drive, then you can open the folders and files and back them up.
Jun 29, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Light turns on but My Computer does not recognize the drive
Sounds like you lost the drivers for your external. W/ out an online PC you cannot download them either. Do you have a friend that could do this on their PC? That is the only way.
Feb 16, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor external portable hard drive. P/N 9NX2DC-500
first it has to be formated to work with it, use manage by right click on my computer then select disk managment from left pane
Oct 27, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor basics hard drive and my xbox 360
Does your drive make any sounds similar to these? If yes you have a mechanical problem and you should get a specialist to work on it if you need that data.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Oct 03, 2008 | Western Digital Caviar SE16 (WD5000KS)...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Maxtor onetouch 4 mini usb 2
You cannot download drivers/software for the Maxtor Mini at the above URL. When you select the Maxtor Mini, you're redirected to a contact form you have to fill out just to get the software. Pretty lame on Seagate's part! I'll think twice before purchasing anything else from them.
Mar 18, 2008 | Maxtor OneTouch USB (A01B120) 120 GB Hard...
Driver for Maxtor 71336A
Vista ULTIMATE has all driver incudes!So you dont need extra driver for ur MaXTOR!Just make sure ur OS runin OK and run UPDATE
Dec 28, 2007 | Maxtor Hard Drive
Maxtor OneTouch III Mini Edition 120GB External USB 2.0 Portable 120 GB IDE Hard Drive Logo
145 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
