Question about Nokia E63 Cell Phone
Network problem E63 ---- Do not get network at my residence. Get network when i use my seem in other handsets. Further frequently calls get disconnected abrubtly with the message 'connection error'. Pls advice.
  • 21 Answers
Ok if you go in to menu>settings>phone>network>network mode> click GSM
This should solve your problem
if not message me on msn
mjsnowdon007@live.co.uk
Michael
Universal Mobiles Coventry LTD
Mobile Phone Engineer
Posted on May 27, 2009
  • Chandra biswas Feb 27, 2011
    Wow Thanks A Lot Michael !!!!!!!!!!!!!!!!!!
    I was just so depressed about it :P Thank You~
My new NOkia E71 fell down in water few days back, i switched it off and put it in sunshine for 3-4 days frequently,Now when i switch it on, it shows no network found message in spite of the fact that i re-formatted it and installed new software, please help to solve the problem.
Thanks !
Muhammad Shahzad Ahmad Khan Lahore, Pakistan
Posted on Apr 11, 2011
2 Suggested Answers
jaisonthomas
  • 356 Answers
SOURCE: E63 ---- Do not get
try reinstalling your phones firmware using nokia software updater.it may solve your problem.if not may be there is a problem with your phones network ic. replacing it will work for you.goodluck
Posted on Sep 09, 2011
No network no signal
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Sep 25, 2012 | Nokia E63 Cell Phone
How to connect to internet
it can be done manually only if u know the ip address of ur network or call ur network operators.
Dec 24, 2011 | Nokia E63 Cell Phone
E63 ---- Do not get network at my residence. Get network when i use my seem in other handsets. Further frequently calls get disconnected abrubtly with the message 'connection error'. Pls...
Sep 09, 2011 | Nokia E63 Cell Phone
Vedio calling in nokia e63 ?
To make a video call..your network should be 3g and also the network which you are trying to call should also be 3g,,,,go to contacts click on the options on contact...hit video call
Aug 18, 2011 | Nokia E63 Cell Phone
My E63 has been blocked by the Optus network...how do i un block it
Your handset can become fully locked due to exceeding the number of attempts to enter the correct unlock code. The type of handset you have will determine what process to follow to see if the handset can be unlocked.If your handset appears with a Code Error or does not unlock with the first or second attempt, you will need to call Customer Service to confirm the code. Once the handset is fully locked it will require manually unlocking from Optus and your handset will need to be sent away.
1 Insert SIM
N.B. Can be unlocked with SIM removed from handset however there is a 5 second time limit 2 Power phone on 3 Type: #pw+15 digit code+1 (where '15 digit code' is the unlock code) 4 Press Hash (#) - SIM Restriction OFF will display on screen for one second
Troubleshooting:
  • If the unlock code is incorrect the phone will display the message 'Code Error'
  • If the user tries to unlock a phone which does not have SIM Lock activated the phone will display the message 'SIM was not restricted'
  • If the syntax (#pw+) is incorrect when entering the unlock code - nothing will happen.
Jun 07, 2011 | Nokia E63 Cell Phone
Im getting sim card registration failed error in nokia e63
Hi, issues like this are related to your Sim card (network),
not your Cell Phone . In most cases, regarding Sim card problem is from the Service Operator. Have you tried the Sim card on another phone? If not,
remove the Sim card, insert it on another phone.
or you can do it in vise- versa by inserting another Sim card on your mobile.
If you can't receive text messages even when it's inserted on another handset,
then you will need to call the customer care of your Network Operator and tell
them your problem, they will help you fix it immediately.
If the same Sim card doesn't not work on another handset,
don't bother to change the settings or to make any changes with it,
first call the customer care and verify from them, you may make mistakes instead of fixing it.
Hope that helps.
Thanks for using fixya.......
Jan 24, 2011 | Nokia E63 Cell Phone
My nokia e63 wont receive calls, what is wrong please?
Go to settings->phone->network and changed the network mode from "dual mode" to "gsm". the other option there is UMTS. and that did the trick. you can always change back to dual as i remember on one of my old Nokia the phone wasn't detecting network and i had to do the reverse (from GSM to UMTS) to get it all good.
some notes:
-Universal Mobile Telecommunications System (UMTS) is one of the third-generation (3G) mobile telecommunications technologies, which is also being developed into a 4G technology.
-Unlike EDGE (IMT Single-Carrier, based on GSM) and CDMA2000 (IMT Multi-Carrier), UMTS requires new base stations and new frequency allocations. However, it is closely related to GSM/EDGE as it borrows and builds upon concepts from GSM. Further, most UMTS handsets also support GSM, allowing seamless dual-mode operation
Jan 08, 2011 | Nokia E63 Cell Phone
How to get gprs settings for nokia 6300
The easiest way to get a gprs settings is from the network operator. Simply call the Customer care of your Sim card operator and ask them to give you your gprs settings, they will ask you few questions with your handset/mobile model and make and will send you the gprs settings as a Service Message so that you can simply open it and save it. The settings will be automatically saved on your phone. You need not to modify or do anything more with it. It'll work perfectly.
There are several codes and activation messages, but I can't give you any tips since I don't know which network you are using or which area are you currently residing.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 21, 2010 | Nokia 6300 Cell Phone
Forgot lock code
Hi Friend,
Network providers lock handsets to their networks in order to protect the investment they made as you have received the handset at a reduced price. Therefore the only people that are able to unlock the handset from the network are the network providers.
If you need a restriction code you will need to contact your network provider, these are the people who hold this information. They should be able to give you this information.
Regards,
Ayyasam
Jun 30, 2009 | Nokia E63 Cell Phone
Nokia E63 Cell Phone Logo
308 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
