Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Popping noise Hi, There is a popping noise coming from the tv speakers. I tried tightening the cables, but it's still making the noise. I also disconnected the cable box, thinking that maybe it was the cable company. It's coming from the TV. Thank you, Patty
  • 3 more comments
  • poppoo Nov 07, 2007
    I TOO HAVE A LESS THAN 1 MO OLD SONY BRAVIA 46" LCD. JUST STARTED AT TIMES TO HAVE THIS POPPING AND CRACKING NOISE FROM THE SPEAKERS. WHAT'S WRONG?
  • Anonymous Nov 13, 2007
    popping sound sporadically coming from the speakers
  • li0nel1234 Dec 11, 2007
    ME 3!!!
    I have a 5 month old 46 inch bravia that pops but only when watching cable tv from comcast. When I play ps3, or watch dvds on the ps3 I don't have the problem. Please help!
  • Anonymous Mar 01, 2008
    TV is only a couple of months old. Speakers started with popping noise.
    Used external speakers; popping comes through them, too. Only with TV
    Reception (TimeWarner Cable). DVD's are fine.
  • haggz Mar 04, 2008
    yup, have the same popping noise problem dont knoow what to do with it, the repair men are coming out to take a look at it. But they said if its not occuring at the time of our visit we cant do anything about it. this sucks!!!i tried to power down tv for 30 seconds didnt work.
I had the same problem. I unplugged the cable converter, waited a few seconds, then plugged it back in. When the box rebooted, the popping noise was gone!
Posted on Jul 17, 2008
Our Sony (almost new) is experiencing sound problems. The sound go off and on about every 10 seconds. Cords appear correctly connected. It sounds as if its coming from the television.
Can you help with this problem?
Thanks,
Mike
Posted on Apr 26, 2008
I get a popping sound on my tv when I change Chanel's
Check all of your audio and video connections to make sure they are seated(connected properly). After doing so,if you still have the popping sound try lowering the volume and see if the popping noise lessens or gets worse.If the noise goes away then you may have a problem with the speakers,either in the tv or in an external sound system if one is connected.
Feb 19, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
How can I get rid of the popping noise?
It is the speakers on the tv fluxing sound is too loud. Change your bass settings or use a different sound system.
Jun 03, 2010 | Vizio VO320E LCD TV
Popping
return it a
VERY common error unit has a bad audio ic
Apr 18, 2010 | Dynex DX-L26-10A 26 in. HD-Ready LCD TV
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
Speakers making a constant poping noise.
this could be due to some static  please get your electrical point checked up 1st  is your tv hooked to watch television thru RF or AV please have the interlink cables if this does not help get back with more details
Oct 15, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Unfortunately, we have the same problem. We hear popping and our sound goes lower. It is not the cable box for us, it's definitely the TV; however, it happens, on our set, after its been on for a few minutes and then goes away after half an hour or so -- however, this evening its been happening for the past hour and the TV has been on for the evening.
Jun 10, 2008 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Popping sound from speaker when changing channels
This noise is normal with the cable box unless you set the cable box on HDMI sound
Dec 26, 2007 | Bose 3 2 1 GSX System
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Popping noise
Does the " popping" noise come through the speakers or from the TV chassis ? If it is coming through the speakers you could have a bad solder joint somewhere in the tuning circuit. If it is a snapping sound coming from the chassis, then you probably have something arcing in the high voltage circiut. If this is the case then you should have it checked out since this can cause other parts to short shutting down you set completely.
Jan 21, 2007 | Hitachi C25-RF35S 25" TV
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
435 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
